Acer
Problem for Acer (ACERMOTHERBOARD)
Acer laptop won't turn on or off!
By cretefor2 on Jan 31, 2009
I have an ACER laptop, when I press the ON switch the machine just goes from ON to OFF continually. This occurs whether driven by mains or battery power. The only way to stop the laptop is to 'pull the plug' and disconnect the battery! Any ideas? (someone mentioned it could be the motherboard?). Many thanksDavy
Comments:
Jan 31, 2009
- Hi rtrahan, Many thanks for your comments & suggestions. Unfortunately you failed to note the FULL content of the problem: I cannot turn my Laptop on to carry out any of the things you suggest!
The problem is: When I press the ON button, my Laptop does not START - it only goes goes in a FULL CIRCLE from flashing light on to flashing light off - this means that I cannot either turn my pc ON or OFF. Have had it looked at 'professionally' and the prognosis is that it is the MOTHERBOARD (just over 1 year old!!!) that is at fault. D
Clarification Request
Posted by the_owl_eye on Oct 12, 2009
I have a similar problem with a nvidia motherboard.
Has any found the reason for the issue?
Posted by rtrahan on Jan 31, 2009
I disagree that it is the motherboard. What logic to say its the motherboard was used? Did anyone troubleshoot all the other things it could be then finally conclude its the motherboard? Let me know if you already went through some troubleshooint steps.
When you hit the shutdown button windows goes through all the programs that are open and shuts them down one at a time. So what if one of those programs is corrupt and it won't shut down properly..then your computer will not shut down properly...so lets check applications first.
Click on start>control panel>Administrative ToolsL>Computer Management>Event Viewer>Applications. Now look down the list and see if you an a program that looks like it was not working right..they should all say "information" or "warning" or something else with may a red x...look at the warning and "RED X" carefully..maybe start your computer and start those programs then try to shut down and see if those are haning up and not shuttig down properly...continue checking programs until you are satisfied you they are all working correctly..let me know what you find out.
Solution #1
posted on Aug 23, 2009
Not Rated)
9339009664
Rank: Wiz
Rating: 79%, 27 votes
if it is a nvidia based motherboard, then i m sure of motherfaulty.
Was this helpful?
Yes
No
Popular Solutions for Acer
Questions and Unsolved Problems for Acer
Do you recommend Acer (ACERMOTHERBOARD)?
Answer
Answer
give me link for intel series v class driver vfoe ethernet
Answer
how do i unlock channels on an ntl set top box?
Answer
CANT,TRACE POWER INPUTS ON BOARD REVAOO
Answer
this acer Aspire 3100 does not recognize ther internal or external keyboard and mouse each time that... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer :
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
