Question about Toshiba e-Studio 232 Black and White Copier
Toshiba e-studio 232 code C970 - Toshiba e-Studio 232 Black and White Copier
  • 1 more comment
  • Ragu Ram
    Ragu Ram May 04, 2014
    check any leakage in transfer/seperation and main charger if not solve check hvt
  • Guru Sangar
    Guru Sangar Jul 05, 2017
    c430
  • rumesh
    rumesh Nov 10, 2017
    my machine erro c970 what's problems
    New Friend:
  • 16 Answers
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check the black color plastic piece mounted on the machine frame where the main charger connects. If this part is damaged, the high voltage will arc through which can cause C970. (found in several machines).
Posted on Nov 28, 2012
C970 show code on main screen of the toshiba e-studio 352 machine plz solve it urgently
Posted on May 07, 2009
    Novelist:
  • 126 Answers
C970: HVT or charge corona.
Remove main charge and trans/sep. coratron units and check --- make sure wires are not broke, clean grid, clean canals of units.
Replace and part needed.
If coratron units are fine --- replace HVT ( high voltage transformer).
Posted on Feb 01, 2009
  • saint Mar 13, 2012
    jpd8 what is the bench mark of its HVT? can you please send me the numbers? and what is your reference in getting your readings.. thanks more power
2 Suggested Answers
fivemayur
  • 414 Answers
SOURCE: resetting error code c970 on toshiba e-studio
Karuna wire break
OR
its side charger problem clean it
OR
replace it
Posted on Mar 19, 2013
Toshiba error c970
clean side cover charger OR replace it
Jul 12, 2014 | Toshiba e-Studio 232 Black and White...
Estdio 232 how can fix to c970 for earr code
[C970] High-voltage transformer abnormality
(1) Is the main charger installed securely?
(2) Check if the spring of high-voltage supply contact point is deformed.
(3) Check if the charger wire is broken or the main charger grid is deformed.
(4) Check if any foreign matter is on the charger wire or main charger grid.
May 03, 2014 | Toshiba E-Studio 3511 Color Copier
Resetting error code c970 on toshiba e-studio
Karuna wire break
OR
OR
replace it
Mar 19, 2013 | Toshiba e-Studio 232 Black and White...
there is no reset code for c970 ...the cause of this is the second transfer roller grounding contact..check if there is foreign materials on the contact ...this error is grounding contact problem
Message comes call for service C970
C970 indicates charging issue. U need to check the T/S block and the main charger for any stain and deform...
Jan 24, 2012 | Toshiba e-Studio 232 Black and White...
MACHINE SAYONG WITH CALL OUT SERVICE CODE C970 HAVE CLEANED FEED ROLLER, CLEANED DRUM AND BLADE, CLEANED TRANSFER AND CORANA WIRES
usually one of the corona wires is broken. double check the transfer and separation wires, or it could be the primary charging wire that is in the drum unit itself.
Apr 13, 2011 | Toshiba e-Studio 232 Black and White...
Dear all error code c970 Hvt carona ,what is the problem on model toshiba studio352 and what is the solution ? Thanks in advance
in the drum there is a pin make sure the drum shaft is making contact if the problem persists change the drum and blade make sure the main charge carona is not broken and the plastick hanger is not broken
Feb 14, 2011 | Toshiba e-Studio 232 Black and White...
Toshiba e studio 350 has a c970 code
C970 indicates charging issue. Need to check the T/S block and main charger for deform/broken wires.
May 22, 2009 | Toshiba e-Studio 350 Copier
Toshibae-studio232 code C970
Hello sir; C970 means high voltage board open , it need to repaire or replace.
Jan 31, 2009 | Toshiba e-Studio 232 Black and White...
F120 fault on Toshiba estudio 232
HOW TO RESET ERROR CODE F-120 IN TOSHIBA STUDIO 232
Jul 09, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba e-Studio 232 Black and White Copier Logo
4,114 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
