Question about Mitsubishi WD-57732 Projection Television
Mitsubishi dlp tv model number wd57732 purchased 2-20-2007
Keep getting error message " blocked airflow tv will shut down in 45 seconds then the tv shuts down and it takes between 4 to 8 restarts to get it to stay on.. The airflow is not blocked and the lamp access door is secure. Any suggestions. Bob
  • 1 more comment
  • Roycetor Feb 25, 2008
    Same model with the same problem. Any answers yet? Thanks
  • Anonymous Feb 28, 2008
    We have a WD-57732 and have the same exact problem with the same error message.  The airflow has NEVER been blocked.  It doesn't matter whether the house temperature is low in the winter or in the high 70's in the summer or in winter heating mode.  We thought we figured out that it shut down on start-up after not being used for a long period, but we have found that is not the case.
  • Anonymous May 09, 2009
    keep getting error message " blocked airflow tv will shut down in 45 seconds then the tv
    suggestions.
I had the same problem on 10/24/07 and i called a Mitsubishi warranty company near me and they came out and replaced the Sensor part # 1299P313010A. No problem since
Posted on Nov 11, 2008
Go to mitsubishi-tc.com. then go under warranty, they have a recall on the thermal sensor and will replace it for free.
Posted on Jul 11, 2008
As of yesterday, I'm having the same problem. Have you cleared yours up yet? I appreciate any help you can give. Thanks Jwin2000
Posted on Aug 22, 2007
SOURCE:
Mitsubishi 73" DLP powers on, through welcome
If you are getting at turn on source and back ground is all blue the set will shut down rather quickly;
I have a suggestion, if it works fine, and if not it will not hurt anything.
with original Mitsubishi remote turn set on and then Menu, 1,2,3, enter.
This is the soft reset that most of these sets have (cannot be sure since Model number above is correct?)
The reset button on the front (if it has it) just shuts the set down and reboots the DM unit inside.
Most of these sets when it is pressed the green light will blink for about 70 seconds and go out; that is the DM unit rebooting and the soft restart is something else.
Let me know what you find before you rate this information.
SD TECH
Oct 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
My tv keeps shutting down when I turn on. The message on the the TV screen said that "the TV will be shutting down in a few minutes". I resit the lamp in the back of the TV and the TV works after I reset...
The first would be excessive dust causing inadequate airflow through the lamp cage. Cleaning the filter may resolve the problem.
It could also be that one, or both, of the temperature sensors could be defective. This is a known problem to the extent that Mitsubishi extended the warranty an extra two years on your model and similar models with the same design.
Mitsubishi Digital Electronics America, Inc (MDEA) 2006 DLP® Projection Televisions Models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD- 65732, WD-57831, WD-65831.
As part of our commitment to quality and customer satisfaction, MDEA is announcing an extension of the warranty coverage to replace the thermal sensor for the above referenced models. For a period of two additional years beyond the one year limited warranty, MDEA will cover the cost of the thermal sensor (parts and labor) at no charge. All other terms of the MDEA limited warranty will continue to apply.
Nov 30, 2017 | Mitsubishi WD-57732 Projection Television
Have a Mitsubishi 52725 52" DLP The TV shuts off frequently. It tells you "the TV with shut off in 30 seconds". It seems warm but I have a fan in the rear to cool it down but sometimes it still...
does it give you the "airflow" message?
if so it needs a new thermal sensor by the lamp, known issue defective sensor..
if not, suspect bad capacitors
there are many bad caps across 3 board , all part of the chassis.
a repair center will ship the chassis into mits for rebuild, about 400 or 500 total bill
May 21, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Error Message
If the set is only 3 1/2 months old, you should still have warranty coverage. Opening up the unit will void the warranty, so don't open up the set. Call for warranty service. In all probability, the air flow sensor is defective. The message you are seeing is a result of the air flow not being detected or not sufficient. In any case, this is a covered problem and should cost you nothing to fix.
Dan
Mar 20, 2009 | Mitsubishi WD-Y65 65" HDTV
Error message
Good Day, drdeath57;
Make sure your air vents are clean but more than likely you should suspect the TV's Lamp Thermal Sensor
Aug 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi slim DLP, keep or sell? can't decide
That problem with the "AIRFLOW Blocked" is now covered by Mitsubishi (parts & labor) Contact a good repair shop and they should fix it free. I had that same problem the tech came out and fixed it in about 30min.
May 19, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Shut Down Message
The repair is to have the DLP engine replaced!!
FYI: The engine also can cause the set to shut down without any display or might even tell you the lamp door is open when it is not.
Feb 01, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-57732 Projection Television Logo
790 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
