Question about Brother SX-4000 Typewriter
Daisy wheel not moving
Installed new correction tape with new ribbon now the hammer is not making contact with the wheel
  • 398 Answers
Did you remember to push the hammer forward?
Posted on Oct 09, 2011
  • Brother Master
  • 3,594 Answers
Be sure the correction tape is dry type, if it is a sticky one it will cause you all kinds of trouble.
DickyO
Posted on Feb 12, 2009
The correction tape is not working
If the correction tape is lifting properly try a resh ribbon and L/O they do get old.
DickyO
Apr 09, 2014 | IBM Wheelwriter 30 Typewriter
WP3400 & AX-12M
  1. Is the daisy wheel locked in the forward position?
    1. Pull the black lever back, away from the platen.
    2. Lift out the daisy wheel and inspect it for damage; replace the daisy wheel if it is damaged.
    3. Re-insert the daisy wheel and push the black lever towards the platen until it locks in place.
  2. Is the ribbon moving?
    1. Lift the ribbon cartridge out of the typewriter
    2. Inspect the ribbon for damage
    3. If the ribbon is silver, it is exhausted and must be replaced
    4. If the hammer has been striking in one place, there will be a clear area near the center of the ribbon.
    5. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance.
    6. Re-insert the ribbon
  3. Turn on the typewriter, insert a piece of paper into the typewriter and type a few letters
    1. Did the hammer move forward?
    2. If the hammer moved, did the ribbon advance with each keystroke?
If the hammer did not move or the ribbon did not advance, the typewriter will require service. If the typewriter still does not make an impression on the paper, your typewriter will require service.
Dec 09, 2013 | Brother Office Equipment & Supplies
When i turn it on it says check printer and its beepin
You do'nt say what make. Turn the machine off. Check the daisy wheel is in correctly, check the ribbon cassette is in correctly, and check the lift off tape is not tangled in the daisy wheel.
Oct 13, 2009 | Brother EM-430 Typewriter
Typing
Check to be sure that the correction tape is in properly and tight. Then make sure that the ribbon (and correction tape) are between the two metal "fingers" and the cardholder (which is the metal thing that holds the paper close to the platen right in front of the ribbon) Is the ribbon moving? You should be able to hold the ribbon up and see each letter on the ribbon. Also make sure the printhammer is locked forward. You should not be able to just reach in and take the printwheel out without the ribbon in place. The only other thing I can think of, is the ribbon got twisted some how. The dull side should be towards the paper.
Oct 07, 2008 | Brother SX-4000 Typewriter
Typewriter
1 - Is the dailsy whell properly installed ? (Has the lever been pressed firmnly ?) is the correct daisy wheel installed?
2 - Have you run out of ribbon ?
3 - Have you pressed the 'spider web' key with + // keys after replacing cassette ribbon, correction tape or daisy wheel?
I have the instruction manual if that helps..
Pleas feel free to advise your email, and I will gladly forward :
Regards TC
Aug 11, 2008 | Brother GX-6750 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Typewriter suddenly will not print!
It's been awhile since I've worked on these.
What is the typing mechanism in here? I believe Brother was using a wheel.
Jun 19, 2008 | Brother EM-530 Typewriter
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Brother ML100 Typewriter:All of the sudden, it just won't type. It seems the 'hammer' doesn't hit the daisywheel. We've replaced the daisywheel, corrective tape, ribbon and still it goes through the...
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Nov 14, 2007 | Office Equipment & Supplies
Brother SX-4000 Typewriter Logo
116 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
