Question about Kenmore 22422 Top Load Washer
No heat when the drier is turned on
Unable to to get any ignition for my gas drier only cold air drier drum turns and blower works that is all it doesappreaciate any help
  • 15,935 Answers
It appears your ignitor or gas valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
    Problem Solver:
  • 16 Answers
Sounds like a bad igniter (cause's a spark that inturn lights the burner) if when you start the drier does it make a ticking sound, if not, replace the igniter, if it does then it may be a bad gas valve, not releasing gas, if so, replace the gas valve. Or it could a bad switch not allowing power to get to your componets. if so replace the start switch.
Posted on Jul 02, 2009
Light pilot reset
If yours is a high-efficiency furnace, you should hear the stack blower start running when your thermostat calls for heat. Next, the igniter should start to glow and remain glowing until the thermocouple opens the gas valve and allows gas to flow to the main burner. The main burner lights and burns until sufficient heat is generated for the main blower to turn on and blow warm air through your house. If any action does not occur in the order described, repairs are in order.
Dec 08, 2013 | Kitchen Appliances - Others
I have have a YORK central air/ heat unit that is not firing up. Thermostats seem to be working but they aren't turning the heat system on. Background info: I had a lightning strike this summer that took...
If the stack blower (fan) does not start when you select heat, the fan control may be defective. If the igniter does not heat up long enough to cause the thermocouple to open the gas valve and fire the burner, the igniter is defective. If the igniter heats long enough but the burner doesn't fire up, the thermocouple is defective.
Nov 26, 2013 | Heating & Cooling
110 74202200 Gas Drier will not heat.Blower works, Drum Turns, Vents all clear. Checked Gas line Gas getting to Drier. Looked at burner: It is clean, no rust, no corrosion, Wires in good shape. It appears...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Mar 31, 2011 | Kenmore Dryers
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Gas drier Whirlpool LGR5634LQ0 drum turns, no heat. Turn off and restart, heats for a while then no heat for drying. Lint is clear, etc... Gas valve is in on position. Not sure what to do next. Check...
most gas dryers will have a problem with the 2 coils on top of the valve.
when these coils are weak or going bad, it will heat for a short while then no heat at all.
if you let the unit set for an hour or 2, it will heat again for a short peroid.
the coils are easy to replace, but do get both of them.
Mar 13, 2010 | Whirlpool LGR5634L Gas Dryer
Working but air is cold. The drum is turning but there is no heat - so clothes are not drying
your element on the electric drier has burnt out and will need replacement. This element is usually located at the bottom left or right side of the drier. It will need to have the back removed to get to it.
Take model and serial #'s to a parts house for proper replacement
Dave
Mar 05, 2010 | Dryers
Drier turns on, tumbles, no heat
your heating element is out,. very easy to replace
Jul 18, 2009 | Dryers
(HVAC) Furnace Not Igniting Quickly
Make sure a back draft in the flue is not happening. Wind can blow it out until the flue heats up. The flame sensor may not be close enough to the burner flame. It may be weak and need to be replaced or if its an optical one it may be dirty and not see the flame very well. Its not wasting much gas but it puts extra wear and tear on the gas controls, is noisy, and, as you said, blows cold drafty air. A gas control system that has issues of any kind is not real safe. It needs to get fixed.
Jan 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Blower works but no heat
If in fact you have the above listed furnace, you do not have a pilot but electronic ignition. You will need to remove the front cover on the furnace, tape down the door safety switch and then have someone help you by turning up your thermostat to a very high setting. Watch and listen inside the furnace. There should be some blinking going on at the control board followed by a small blower fan starting up. Then after 10-15 seconds there should be a click followed by an orange glow viewed thru the viewing window to the burner section. In a few seconds the gas valve should click and the burners will ignite. There is a safety switch that will sense flame and then keep the gas going to the burners. If it does not sense it, it will shut it off within 10 seconds. If all is well so far, your blower will turn on in about 90 seconds after flame. There is a diagnostic code chart on the back side of the access door if you get an error code (blinking) on the control board.
Always check little things like air filter, condensate drain and broken or loose wires.
Nov 05, 2008 | Goodman GMS90703BXA Heater
No heat blower motor no working
Okay, I think we need to back up a bit here. I need to know, first, if the dryer ignites. This is a GAS dryer, correct? I need to know if the igniter is glowing, and if you can hear the gas start flowing when you have ignition. If not, this could be a simple igniter or gas coil problem. If there is ignition and the drum is turning, do you have air flow coming out of the dryer vent exhaust? If there is air flow, you cannot possibly have a blower wheel problem. We need to rule out some possibilities before we start disassembling the dryer. I'm a bit miffed as to why someone would tell you that the motor was the problem. Since I was not there, I need to know as many symptoms that you can provide, so I can give you with a correct assessment.
Jun 15, 2008 | GE DPGT750GC Gas Dryer
Kenmore 22422 Top Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Robert Rankin
