I m doing m tech (information security) .
So i want to do work at security.can u suggesh me that what should i do. thanks u...
  • 565 Answers
Start with downloading various (free) software firewalls, get to know them very well, then delete it and install another, and another, until you know each of them very well. In the mean time, read as many Usenet posts as you can and try each
"solution", (being aware that some of the solutions we not be correct). Just search google for
usenet."
G
Also you can go to google and type in "firewall forrums" or something similar and you will find all sorts of info. Then work your way up to installing routers with built in firewalls. IT goes on to many other adventures, but get the basics down first.
Check out your local tech. schools and community colleges too.
Them you get to study (free) downloads of antivirus, antispyware,
like Spybot, Superantispyware, and AVG. (all free).
Have fun
Posted on Jan 31, 2009
Someone tried to steal my 2000 Chevy s10. I replaced the ignition cylinder which came with two keys. I tried to do the 30 minute relearn but the security light doesn't stay on long enough to do the...
For the anti-theft system in your S-10 , no key relearn is needed . No chip (transponder) in the key ! Has a sensor that is part of the lock cylinder housing , and a magnet that is part of the lock cylinder ! When you turn the key the magnet passes the sensor creating a signal that is sent to the BCM - body control module ! The BCM will send a password to the vehicle/powertrain control module (VCM/PCM). When the VCM/PCM receives the correct password the VCM/PCM allows the fuel injectors to operate normally. The passlock™ system requires the VCM/PCM and the BCM to communicate the various functions in order to operate. These functions transmit over the class 2 serial data line CKT 1807. For an explanation of the class 2 serial data operation refer to Data Link Communications Circuit Description in Data Link .
Is the security light lit ?
Conditions
Use this procedure after replacing:
• Passlock™ Sensor
• BCM
• VCM
• PCM
10 Minute Re-Learn Procedure
Tools Required
• Tech 2
• Techline terminal with current SPS (Service Programming System) software
Connect the Tech 2 to the vehicle.
Select "Request Information" under "Service Programming".
Disconnect the Tech 2 from the vehicle and connect it to a techline terminal.
On the techline terminal, select "Theft Module Re-Learn" under "Service Programming".
Disconnect the Tech 2 from the techline terminal and connect it to the vehicle.
Turn ON the ignition, with the engine OFF.
Select "VTD Re-Learn" under "Service Programming".
Attempt to start the engine, then release the key to ON (vehicle will not start).
Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF (the vehicle is now ready to relearn the Passlock™ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK).
Turn OFF the ignition, and wait 5 seconds.
Start the engine (the vehicle has now learned the password).
With the Tech 2 (scan tool), clear any DTCs.
your best bet , take it to a GM dealer
May 28, 2017 | Cars & Trucks
I have nokia 2690 whose security i have forgotten and i cannot open my security code pl help me regarding this matter by providing me a master code
To unlock your phone, call your cellular service provider's Customer Service and request Tech Support assistance. (Tech Support assistance is free.)
Tech support will ask the make and model number of your phone so have that information handy. It can usually be found under the battery.
Tech Support will then verify that you are the owner of the phone. After doing so, they will give you a master unlock code, (or a PUC code) which you'll enter on your phone's keypad.
This will unlock the phone where you can enter a new PIN. (Don't forget your new PIN)
We cannot provide master unlock codes on FixYa as we cannot verify the ownership of phones. You'll have to call your cellular company.
Feb 18, 2011 | Nokia 2630 Cell Phone (Unlocked) - Black
I want to the security code lg gm730. thanks
Contact your cellular service provider and request Tech Support assistance. They will provide you with a Master Unlock Code for your phone. After entering it, you can then change the PIN to one you'll remember.
We cannot provide Security codes on FixYa as we have no way to verify the ownership of your phone.
If all else fails, visit this website: http://www.onlinegsmunlock.com/unlock-your-phone/rs7wp2/
Or, you can Google "Secret Codes LG GM730" and review the information from available web sites.
Jan 26, 2011 | LG GM730 Cell Phone
How to configure xaamp with filezilla ftp
You will need to know the following first
Username
Password
Host/Server IP
Port
Any security setting set by the host
Once you have this information you can then plug in the information you should be able to access the FTP directory.
The staff at Live-Tech would be happy to help you
Please contact then at http://www.mylive-tech.com
Jan 01, 2010 | Microsoft Windows Server Standard 2003 for...
Simple Tech USB Drive will not work
I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
Oct 20, 2008 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
IEEE 802.11G BROADBAND WIRELESS
Reset the router to reset the username and password.
http://tech.yahoo.com/blog/null/11006
After this you should be able to use the factory login to add the security.
Aug 19, 2008 | ConnectGear Wireless Ethernet, Broadband...
I have a 93 Toyota Camry LE That has a Titan T-3003 alarm serial #A013204 and I don't have the remotes it works fine manually but it will be easier with the remote. please help me out..thanks
Pls try Auto Tech Security Systems.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 24, 2008 | Toyota Camry Cars & Trucks
Computers & Internet Logo
David Payne
David Payne
