Question about Toshiba e-Studio 232 Black and White Copier
Toshibae-studio232 code C970
When the machine is raedy and you press print the machine'misfeed and'll display C970
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; C970 means high voltage board open , it need to repaire or replace.
Posted on Jan 31, 2009
    Problem Solver:
  • 5 Answers
U should have to check the main charge unit.some times u have to replace the main charge unit.its a high voltage leakege problem. try this remove the main charger cleaner. green one. and u can sole the problem.
Posted on Mar 19, 2009
  • Toshiba Master
  • 524 Answers
It can be also caused by Main Charger unit, and Transfer/Separation unit.
Posted on Feb 13, 2009
Resetting error code c970 on toshiba e-studio
Karuna wire break
OR
its side charger problem clean it
OR
replace it
Mar 19, 2013 | Toshiba e-Studio 232 Black and White...
My problem toshiba e-s352 Code C970 and print is not ok please sole
C970 is an arc check your bios pin on maincharge as well as the transfer seperation unit its loosing powerto one of the charges
Aug 17, 2011 | Toshiba e-Studio 350 Copier
C440 error in toshiba e studio232 how to solve
Hello
Please switch the machine off.
While holding down 8+0 buttons switch the machine on.
When the machine is in test mode, input 400 and press the start button, input 0 and press enter on the display.
Switch off the machine wait 1 minute and switch the machine on.
If the error reappears the thermistors and thermo need fuses need to be replaced.
I hope that sorts out the error.
Regards
Apr 17, 2011 | Toshiba e-Studio 232 Black and White...
turn off the machine. turn of the main power switch. turn it on holding down the 0 and 8 keys. when the machine turns on and comes to ready input the number 400 and press start. you will see a number from 1 to 30 note this number it may be important later on. press the number 0 and then press the ente key on the display. turn the machine off and back on normally. the machine should work. if it does not you will need a part. when you call for service make sure to tell them that in 08-400 you got a vale of whatever that number said. it will help them bring the appropriate parts.
Dec 30, 2010 | Toshiba e-Studio 232 Black and White...
How can i fix the error code C970 on my toshiba e-studio 230?
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Nov 01, 2010 | Toshiba e-Studio 350 Copier
TOSHIBA e-STUDIO232 fax settings for VoIP line
No settings, a fax machine will not work reliably on a Digital Phone Line.
Apr 12, 2010 | Toshiba e-Studio 232 Black and White...
Had a power outage, not a surge, now reads call for service.
Press "clear" and "8" simultaneously and hold, this should display the error code...what is the error code?
Jun 14, 2009 | Office Equipment & Supplies
Toshiba e-studio 232 code C970
3. Before you replace the HVT board, check the black color plastic piece mounted on the machine frame where the main charger connects. If this part is damaged, the high voltage will arc through which can cause C970. (found in several machines).
Jan 31, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba e-Studio 232 Black and White Copier Logo
781 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
CheckitRight
CheckitRight
pkwc
Electro Med Services...
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
