Hi have just purchased a Mistral MPAC50 portable air conditioner, was wondering if you could help me with some questions about the drainage system??
  • 1 more comment
  • RenR Mar 29, 2009
    We cannot get it to drain.  I have to empty the air conditioner manually after every use.  What are we doing wrong?
    Any help would be greatly appreciated :)
    Ren
  • Kent Guidry
    Kent Guidry May 11, 2010
    Please tell me your question, and I will help you as best as I can.
  • Ken Bledsoe May 11, 2010
    What is your question?
  • 400 Answers
Yes, we could.
Posted on Mar 12, 2009
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
Mistral mss25
Any HVAC supply house will have this.
Oct 09, 2013 | Heating & Cooling
How to reduce temperature in mistral mpac50 sitcom
Have you tried changing the mode to the snow flake looking symbol?
Nov 30, 2012 | Heating & Cooling
Hi, my daughter has just moved in to a property with a mistral mss6.5 system, with no instructions left behind on how to operate it. they replaced the batteries in the remote, but do not know how to reset...
Without being able to see the remote, there are three possible solutions which spring to mind. Firstly, contact the people from whom they bought the property, or place an inquiry through the sales agent. Ask if they have the manual, or if they can explain how the remote functions.
Another possibility is to take the remote into a local store that installs and repairs air conditioners and ask how the remote works. Presumably when she bought the house your daughter was told that the unit was in working order, so if after a sales or service assistant has shown her how to operate it, the air conditioner still won't function, she need to tell the house agent about it.
Finally, she could use the link below to the Mistral website and send them a query and also ask for a manual. I hope this helps!
http://homeappliance.manualsonline.com/ex/product/headline/m/mistral/d/air_conditioner/p/MSS6.5
Aug 21, 2011 | Heating & Cooling
Hi, my mistral (MPAC50 just started coming up with an error code E5. it wont go into airconditing mode and only uses the fan
E5 Outdoor activation of compressor over heatprotection or motor lock
Compressor overheated due to condenser block or fan motor lock. Clean condenser/replace out door fan capacitor.
Dec 30, 2010 | Heating & Cooling
Hi, I have a Convair TRB portable air conditioner and I dont have an instruction manual. I'm wondering about the drainage outlets on the rear of the unit. The top one (half way down) has a black tube...
No the bottom hole should not be plugged. the bottom hole is the drain for the condensation. If you plug that hole the water will fill up and damage the unit.
Jan 31, 2010 | Heating & Cooling
Mistral Air-con split system shows F6 fault! What does it mean?
F6 INDICATION MAY MEAN THAT THERE IS A PROBLEM WITH THE BLOWER MOTOR. WHEN THE BLOWER MOTOR GETS HEATED UP (WHEN ITS WINDING BECOMES WEAK) THIS MAY HAPPEN. SO U GET UR BLOWER MOTOR AND PCB BOARD CHECKED.
Nov 23, 2009 | Heating & Cooling
Windchaser PACRWC-HP Portable Air Drainage Issue
obviously condensate sensor is fault. You may need to replace it. Yes it okey to turn it on now.
Oct 11, 2009 | Windchaser Portable Air Conditioner
Need instruction manual for mistral mpac140 portable air con
They do not have a downloadable manual that I could find but I have included their contact info so you can contact them directly. They may be able to get you the info you are requesting.
http://www.mistral.com.au/contact_us/contact_us.asp
Apr 01, 2009 | Heating & Cooling
Everstar portable air conditioner
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Sep 08, 2007 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
476 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
