Question about Elna 2007 Mechanical Sewing Machine
Cannot get to the lightbulb on an Elna SU sewing machine to chang
Need to change the bulb, I do not see how to open it. or pull the bulb out, I cannot just pull, I'm afraid I'll break the bulb. I was not given a manuel with this machine. Thanks.
  • 333 Answers
On the left hand side of the machine on the end cap.
Changing the Light Bulb
The sewing light is located behind the face plate.
UNPLUG THE MACHINE. Wait until the bulb is COOL before you touch it!
1 2 3 Remove screw cap , screw and face plate .
To remove: pull out bulb from socket.
To replace: insert bulb into socket.
Attach face plate and insert screw and screw cap.
NOTE: Replace bulb with same type rated 12V, 5W.
I hope this helps. Don't forget to rate my answer.
Posted on Jan 31, 2009
  • Arnell VerHoef
    Arnell VerHoef Mar 20, 2014
    No, there are not any screw holes where you said. The bulb is up in the main part of the front and almost inaccesable.
  • Elna Master
  • 1,133 Answers
If your SU is an Air Electronic then it is a little different. Firstly unplug the machine. Take your mini screwdriver that came in your kit and look at the top of the machine above the needle. There is a little hole there, put the screwdriver into the hole and push down on it, this lowers the bulb holder in the head of the machine down below the casing on a slant towards the back of the sewing bed, its spring loaded so you may need a second pair of hands to do it the first time.
Cannot get to the lightbulb on an Elna SU sewing m - 10_16_2011_12_08_29_am.jpg
Hold the screwdriver down, and grasp the bulb, push it up and twist anticlockwise to undo the bayonet fitting. Push down and repeat the process to insert the new bulb, turning clockwise to insert it into the bayonet fitting. Release the screwdriver and it will retract back into position.
Posted on Oct 16, 2011
  • 2 more comments
  • Liza Rudolph Nov 12, 2011
    Perfect! Thank you!!
  • Linda Ziegler Jan 10, 2013
    Thank you so much. I never would have changed the bulb without your help. Linda Z.
  • Arnell VerHoef
    I seem to have this one and after pushing it down I still couldn't get the bulb to twist in. Maybe my bulb is too short? Where can I get a correct length one?
  • Tally Girl
    Tally Girl May 07, 2014
    Arnell, you need a longer bulb yes, code #444100, its a 15w bayonet. I bought 5 on line via Ebay ex USA last time i needed some here in Australia as they are expensive at my local Spotlight. But any Elna dealer should be able to sell you one, or are you in USA, if so try sewingpartsonline.com, $5.99
Tip
How to change lightbulb in Air Electronic SU TSP Jubilee 500 and Carinas
If you own an Elna Air Electronic and blow a lightbulb then here is the instructions to change it. The lightbulb will be a bayonet fitting 15w but maybe remove old one first to make sure you get the right length bulb at the shop.
Hold the screwdriver down, and grasp the bulb, push it up and twist anticlockwise to undo the bayonet fitting. Push down and repeat the process to insert the new bulb, turning clockwise to insert it into the bayonet fitting. Release the screwdriver and the bulb holder will retract back into position.
If you have a Stella air electronic then it is very similar except for the location where you need to push. On the Stella look at the rear of the machine head above the bobbin cover and you will see a little slide mounted right at the end of the rear casing. Same thing but for these, put the screwdriver across the top of the slide horizontally, then push down on it to lower the bulb mounting.
That's it! Happy sewing.
on Oct 19, 2011 | Elna Sewing Machines
Need the light bulb for the 6005 Elna. I've had this machine for many years and its been a real work horse, but now the light bulb has gone out in it.
Looking here, it looks like a capless bulb like in cars.
Lamp Socket Unit Elna 395723 43
In fact it is, a 12 volt 5 watt capless auto bulb
Changing the Light Bulb The sewing light is located behind the face plate. Unplug
the machine. Remove screw cap and screw. Pull away
face plate.
Pull out light socket. Pull out light bulb. Push in light bulb
with pins aligned to holes in light socket. Push in light
socket.
Replace face plate, screw and screw cap.
NOTE: Only use same type light bulb rated 12 Volts, 5
watts
6005 Elna light bulb Google Search
similar
ELNA 6200 Instruction Manual Changing The Light Bulb Feed Dog
Feb 05, 2018 | Sewing Machines
How does one change the bulb on an elna 6003 sewing machine
Hopefully you have a manual that shows how to replace the bulb. Online Elna manuals have a fee.
Perhaps something here will help:
Change bulb elna 6003q
How do you change light on elna 6003 sewing machine
Watch Me For Minute Elna Lightbult Change
Jun 06, 2016 | Elna Sewing Machines
Need manual for elna su
perhaps if you google the make /model and manual you will find help
Mar 20, 2014 | Elna Sewing Machines
I have an Elna 6003Q sewing machine. My light bulb went out and I need to replace it. How do you get it out and replace it?
some call it a lamp cover door or face plate it's on the left side of the sewing machine
some sewing machines have a hinge at the back of the face plate, you can gently pull it open to change the bulb
some machines -in the middle of the face plate there is a plastic plug, use a screw driver to gently lift the plug & then unscrew the screw & change the bulb.put the face plate back on put the srew back in & put the plug back in to concile the screw
Sep 27, 2010 | Elna 2007 Mechanical Sewing Machine
I need to replace the light bulb on my Elna SU 62C sewing machine and I am not sure how to remove it. Has been in the machine since I purchased it in the early 70s.
Switch power off first. On the top left hand side of the machine towards the front is a small hole. Insert small screwdriver in hole and push down. The light bulb will appear underneath just to the left of the presser foot. Whilst holding down the screwdriver firmly, turn bulb anti-clockwise pushing slightly upwards at the same time. Bulb should dislodge.
Feb 07, 2010 | Elna Sewing Machines
Burned out bulb.
Generally on an Elna there's a little hole on the very top of the sewing machine directly above the bulb.
Pushing a long, skinny stick (like a screwdriver,) down into this hole will push the lightbulb and socket assembly down to where you can actually access the bulb without having to try to skvoosh your fingers into the tiny space.
-R
Aug 28, 2008 | Elna Quilter's Dream 6003Q
Elna 2007 Mechanical Sewing Machine Logo
1,855 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
