Question about Car Audio & Video
I am about to put my 6x9 speakers in my car. i would like a little advice if possible. it will not be a tricky job as all the connections have been done (by a car garage). all i need to do is put the speakers into some mdf wood and then fix that under my parcel shelf. Do you have any helpful information on what the best way to do this is, i.e. how to secure the mdf to the original parcel shelf. I want to put the speakers underneath the existing parcel shelf for added security. many thanks Harry
  • 38 Answers
Typically the best way would be to remove the interior trim piece from the shelf. Then have a friend hold the MDF board up from inside the trunk. Then run either screws or bolts/nuts through from the interior all the way through the MDF. Replace interior trim piece and it should be held in tight.
Another less intrusive way would be to use a strong adhesive, such as "Liquid Nails" to secure the MDF to the bottom of the shelf. You'd need to figure a way to hold the MDF to the bottom of the shelf for quite awhile (8-24 hours) to make sure their is good adhesion.
Posted on Jan 31, 2009
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
How to connect 6x9 pioneer speakers
Do you mean the Factory Speaker (Conecters) If you do they will have to be changed, To the same type of connecter that is on the speaker wires that come with the 6x9"s
Dec 05, 2012 | Pioneer Ts-a6974r Car Audio 6"x9 6x9 3-way...
Will a 6x9 fit in where the stock 6x8 speaker is on a 1991 xlt
No, the 6x9 will not sit flush in the 6x8 opening.
It's possible to enlarge the cut out but rear clearance may be an issue. The 6x9 speaker is deeper and has a larger magnet.
Another choice is to move the speaker out with a spacer NLT 3/4", this may require cutting a hole in the plastic panel and using a speaker grill.
Sep 07, 2010 | 1991 Ford Ranger Supercab
2001 EXPEDITON TRYING TO FIT 6X9 IN THE DOORS HOW CAN I MAKE THAT POSSIBLE WITH SAME DOOR PANELS
You can mount them on the inside of the door, a small bit of speaker may be a bit smaller than the opening but that way you can use the same door panel and you don't have to hog out the door at all. Shouldn't degrade the sound quality very much.
Jan 22, 2010 | AudioBahn CHROME 6X9 SPEAKERS PAIR 800...
Is it possible to install 6x9 speakers in a 1999 isuzu rodeo??? if so where?
You could use a spacer and install them in anything.
Most audio accessory stores carry 6x9 spacers in 2"
Jan 03, 2010 | Pioneer tsa6970s 6 x 9 3W Speaker Car...
Speaker addition
if i was you, i would make some speaker boxes that arent that fat, but will actually fit in the back window. otherwise, u could try to put 6x9 holes in the back below the window. but id try making some boxes
Dec 12, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
I need help on sound built in
u may be able to custom fir the 6x9 into the rear of the vehicle, if you don't want to do that, you may be able to fit them into the spots in the doors, but that still may be a custom job. u could always go with boxes, individual boxes that you could put on the floor on maybe on the back deck where usually the 6x9s would be located. if you dont like that idea, you might try a body shop or electronics retailer because there is definitely a way to fit those speakers in the doors or on the rear deck, it just won't be an easy job for a beginner, you have to cut holes
Aug 09, 2009 | Car Audio & Video
6x9 hook up
yes conect the wire to the new speakers and it has to work
Feb 17, 2009 | Blaupunkt PCxt652 Coaxial Car Speaker
Blown 6x9 subwoofer???
Any speaker will work. It's better if you put in the same kind, but if it's just a stock system it shouldn't matter.
Jan 07, 2008 | Car Audio & Video
Car Audio & Video Logo
123 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
