Question about Miele DG155-1 Steam Oven Single
How do I descale a Miele steam oven?
Do I place the descaling tablet into the water container with water in it or into the oven or???
  • Anonymous Mar 30, 2014
    doesn't work at all
Put the tablet into the steam generator with about 1ltr of cold water, select the cleaning cycle on your oven. let it go through the cycle.
Hope this helps
Posted on Feb 12, 2009
  • haziet Sep 02, 2010
    Hi there, so do you put it in the plastic jug thing that you usually fill with water..also, where do you get the cleaning tablets from?
    Many thanks
  • Ptour Aug 29, 2011
    Can you please let me know where i can purchase the tablets?
Miele DG6500 steam oven
Mine did the same thing. Unfortunately, I had to get Miele out to reprogram it. They said it was a "software" glitch and Miele are the only ones with the electronic program to access the software to fix it.
Sep 17, 2017 | Ovens
LOOKING TO BUY A SECOND HAND RATIONAL OVEN CPC 61, BUT WANT TO KNOW HOW OLD IT IS. ANY IDEAS OF WHERE TO FIND THIS INFORMATION? I HAVE THE SERIAL NUMBER: E61CD0208107
E for electric
61 for model/size
CD ummm, control type?
02/08 I think is feb 08, but I would like someone else to confirm that please?
Also, what is service history, did it have a good water filter? was the tank flushed daily and descaled annually?
Oct 17, 2013 | Ovens
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
Error code On Miele Steam oven - oO
o O means that the unit needs to be descaled. See your owners manual for the procedure. If the unit displays O - - o, the safety lock has been activated. Again, see your owner's manual.
Feb 01, 2010 | Miele DG155-1 Steam Oven Single
Miele steam ovens
A dedicated circuit is recommended. 208-240V 20A L1 L2 & Ground, Neutral not required.
Jan 30, 2010 | Miele DG155-1 Steam Oven Single
Is there such a thing as a descaling unit for a blodgett combi oven model bc14g/ab
These combi ovens are so prone to problems if you do not have descaling filter system hooked to the COLD water supply (the only water that should be fed to this unit) for your generator inlet. The other water hookup is for your condensate drain (condenses steam leaving cook chamber headed down the drain) and it does not need to be filtered but, also needs to be COLD. These decaling units are quite pricey but, a service call to replace the generator (boiler in laymens terms) will cost 3 times as much & the unit will be down for days waiting on parts. Call Blodgett w/ your model # & talk w/ technical service & ask their recomendation. They can be reached @800-331-5842 & follow the prompts. Depending on your water conditions it is still recomended to descale the unit on a regular basis using a QUALITY descaler (not the junk you buy from Sysco or Dollar general) Cleveland descaler is the BEST.
Jul 24, 2009 | Blodgett Combi® BC-142G Stainless Steel...
Difficulty in cleaning my Miele combi oven
I have the same cleaning problem as Denise503 with her Miele combination oven - help if anyone has a solution - I have got to the stage where I don't want to use it.
Apr 10, 2009 | Ovens
Ovens Logo
2,903 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
