Question about Philips Magnavox 27MS343S 27" TV
Dvd Player I have a dvd player built into my Magnavox tv. I can not get the dvd to eject. It does not even have a light on that tells me a dvd is in the player. Is there any way to manually remove the dvd? or fix this problem.
    Problem Solver:
  • 5 Answers
Probably the eject motor is non-functional.the tv can be opened and the dvd removed manually without affecting the tv section. the problem can be fixed by replacing the motor.
Posted on Aug 24, 2007
SOURCE:
I own a Magnavox TV with built in DVD player. The DVD will not eject the disc. How do I get it out??
It sounds like the DVD may be jammed in the mechanism. Unfortunately, there is no easy way to get that out if the eject button on the TV and remote are not working. You will need to find a local electronics repair shop and take the TV to them to get that DVD out.
I would google electronics repair and your postal code and give a couple of shops nearby a call to see if they can help and how much it would be. Hope that helps.
Sep 12, 2018 | Magnavox Televison & Video
I need the codes to program a magnavox tv with built in dvd player with this remote
Your universal remote should have a code search feature that allows you to search through its library to find a code or codes that will work. You might need two separate codes for the TV and the DVD player.
Jun 19, 2015 | Audiovox RCR314WR Universal Remote Control...
Soniq tv with built in dvd player says no signal on dvd mode
DVD unit has gone to dvd heaven. Not cost effective to repair. See if you have inputs so you can use an external player.
Feb 20, 2012 | Televison & Video
In the combo tv and vcr their is no pin hole near the dvd so how will I eject the cd
The best way, in my experience, is literally disassembly. Pull the back off of the television and be very aware of the different ribbons connecting PCB's. Note where everything was plugged in (take pictures if you must), and find where the built-in DVD player is mounted (should be attached to the back cover). Remove the player and disassemble. It's generally fairly intuitive. You should be able to reduce it into a pile of parts and get your DVD out!
Word to the wise: I'm an electronic service technician, and I have seen a good many of these built-in DVD players fail. Actually, they all tend to fail within a year. They are also 30.00 units. No 30.00 unit has ever been even close to a good piece of equipment. That said, don't replace the internal DVD drive. Just buy a component player.
May 14, 2011 | Magnavox 32MD359B 32 in. TV
TV DVD VCR combo eats tapes and now won't eject DVD's
Its shot, time to get a new one. dvd players are now only $20
do you have a newer lcd tv. Id say look into getting an upconverter,itll play your dvds at 1080 :) better picture.
Feb 27, 2009 | Philips Magnavox MWD200G DVD Player
T.V. shuts off when I try to play a DVD in the built-in player
Try putting in a VCR tape let it load and hit stop. If the set stays on it's the VCR deck causing the problem. It will be either be bad sensors or LED or possibly the mode switch. Let me know if this helps.
Oct 15, 2008 | Philips Magnavox 27MS343S 27" TV
Phillips/Magnavox 26MD255V
manual eject button is on side were you load the disc
Nov 09, 2007 | Philips 26MD255V 26 in. LCD TV/DVD Combo
DVD player won't eject
No but I'm having same problem and the dealer sugested just buying a new dvd player cause cost of repair or replacement is unbelivably high,approx 500 canadian for new dvd sleeve, the guy tells me they don't fix them they just put a whole new dvd player in from hthe manufacturer. Pretty disapointing considering how nice it is to have it built in.
Dec 24, 2006 | Hitachi 46W500 46 in. TV/DVD Combo
Philips Magnavox 27MS343S 27" TV Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
