Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher low water presure upper level
I have a 1 year old whirlpool dishwasher Quiet Partner 1. I have very little or no water in the upper level. The lower level washes ok. i tryed to see if anything was block. every thing was ok. All i can see is that there is not enought water presure going up to the top level.
Thanks
P.M.
  • 4 more comments
  • Anonymous Feb 06, 2009
    Have the same problem with our dishwasher (1 year old quiet partner 3)
    I ran the machine with the door open and its obvious that there is insufficient pressure - top arm doesn't turn - water trickles out of arm?
    Was looking on net to figure out how to clean the pump
  • Anonymous Feb 09, 2009
    same exact problem amd the upper arm is not spinning
  • wrestlermom Mar 13, 2009
    Top spray arm not getting enough pressure and top rack dishes not clean. Some water get there and arm spins somewhat. Is the spray arm seal supposed to have a split?
  • Alice Smith Mar 26, 2009
    I have the same problem: the upper level dishes are not washed.
  • sadsally Apr 21, 2009
    Some of the dishes on the top rack get clean and others don't. Also, there's a crackling sound as dishwasher fills. Please let me know if there's something I can do to fix dishwasher.
  • Anonymous May 02, 2009
    top rack not getting any water
    Genius:
  • 1,550 Answers
Since you have low pressure
  • Check the float switch inside the tub, it should move freely up and down.
  • Check the harness to the motor
  • Check start capacitor on the left side of the wash motor
Posted on Jan 31, 2009
Whirlpool dishwasher quiet partner lol is not cleaning dishes on top rack
could be a few things clean inside filters and screens listen to it does the wash motor during wash sound strong like it tossing water around in there open the door during the wash see if kicks some water out at you. If it sounds and seems like its working ok then some units have a rubber check valve little flapper in the tube that goes up the back wall to the upper spray arm i have seem break off and clog that tub not allowing any water to the upper spray arm.
Dec 24, 2016 | Whirlpool Dishwashers
Whirlpool quiet partner 1 is suddenly loud
Dear Sir : please see the diagram attached.
May 08, 2012 | Whirlpool Dishwashers
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Quiet partner 1 top rack does not get clean at all
I would suspect you have debris in the pump that is causing a pressure drop so the water is not spraying well in the upper arm.
Try this procedure to clean out the sump. Let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 24, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Upper Arm Not Spinning on Whirlpool Quiet Partner I
Possibly, the intake screen under the lower arm is partially plugged. Take the upper arm off and inspect the holes for plugging and that the seam between upper and lower halves is not split. Our Maytag split the same seam--fixed by drilling a number of very small holes along the split and sewing it shut with fine wire.
Aug 08, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Apr 12, 2009 | Dishwashers
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
No water or rotation to upper rack
if its not letting in enough water then this can happen.check water connections or a motor fault.
Jan 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Whirlpool GU2400XTP Built-in Dishwasher Logo
782 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
