Question about Motorola Mobility RAZR V3
How can i change my ringstyles?
I keep on changing my ring styles but eveytime i do it it just bring me back to the setting... plz help me solve this problem.. here is my email add... [email protected] tnxs!
  • Mariz Arceo Jul 31, 2007
    wwwaaaaa... i can't fix it...
After opening the lists of ringtones press middle key on phone then switch to card memory to phone memory. Then only you can change your ring styles.
Posted on Jul 30, 2007
SOURCE:
My phones ring style is set to loud detail and volume is at the highest being 7,when I recieve a call it is silent?
Hi There,
As per my understanding you have set your ring style profile to loud and highest volume 7 but still ur phone phone rings on silent when someone calls..
Please change the Profile setting once again as mentioned below:
How to change call alerts and styles?
1.From the general menu, select "Settings" > "Ring Styles" > "Style Detail"
2.If you select one of the styles, ie. "Loud" you can then highlight by scrolling down on the wheel & select "loud detail" & press on the "change" button (top right corner key).
3.Here you will be prompted to change any feature available to the "loud" style: volume, ringtone, alerts, voice mail, text messaging sounds, reminders beeps etc etc. All you need to do is to select the feature you need to change with the directional wheel and press the "change" button for each.
If you think my solution helped u to resolve ur issue please do vote for me..
Thanks
Enjoy!!!
Oct 28, 2010 | Motorola Mobility RAZR V3
MOTOROLA W376G...turn off phone on ringtone
Hello!
Set phones ring style as "Vibrate then Ring" , "Vibrate" , or "Silent" to avoid the power on alert.
I set my ring style to "Vibrate then ring" so that I dont have to change the settings everytime I turn it on or forget to so when I receive phone calls or alerts it still rings & then I dont have to go back and change the settings again when I turn tha phone off so that is dosent have the power on alert.
This is the Only way I have found to turn the phone power on tone/alert off.
Change Ring Style:
-Go to Main Menu
-Settings
-Select Ring style
-Then choose change, & set it to the ring style you want.
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
Cant turn key pad noise off ...Is this possible?
I also had the razr and couldn't stand the noise. Heres what you'll do to solve it:
1) Menu
2) Settings
3) Audio
4) (ringstyle) Detail
5) Change the key volume for each that would actually ring.
Hope this helps,
Joe
Feb 19, 2010 | Motorola Mobility RAZR V3
Vibrate
1 go to settings
2. ring style
3. click the little button top left on phone under "select". it will let you change your ring style
4. scroll to vibrate
5. click same little button under "select"
6. keep clicking "back" - the little button top right on phone under "back"
Jan 29, 2010 | Motorola Mobility TracFone C139-4 Cellular...
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Motorola w377
Like most of the W377, this one's very odd. The only way I know how to do this is to switch off all Key tones. Key volume is part of the Ring Style menu, so:
>Settings
>Ring Style
>Ring Detail
>Change
> On the Detail menu use the 4 way selector arrows to cursor down to Key Volume
>Change
>0
>Ok
>Back out
NB The Ring Style settings for ALL ring parameters (Ring Volume, Line 1, Text Msgs, Voicemail, Alarm, and Key Volume) change whenever you select a different Ring Style, so you can set up one ringtone in Loud Ring but get a different one for Soft Ring, a different one for Vibrate and Ring, a different one for Vibrate then Ring, etc.
For the sake of sanity (and to avoid the alarm waking me up with a loud blast of Bach when I wanted a quiet 'Ding') I have set the same ringtones etc in all of the above profiles.
BTW whenever you can't find a menu you need, try pressing the black round button (OPEN MENU) in the middle of the 4 way selector arrows - it opens submenus that can't be accessed any other way.
Hope this helps.
Jan 02, 2009 | Motorola Mobility W377 Met Silver/Pink...
No ring, only vibrate
if the ringtones ring from settings or the songs play then it will be surely the settings problem please select ring and vibrate instead of vibrate only and if it doesn't works then go to a near by repair shop and ask them to check and change the buzzer
May 02, 2008 | Nokia 6288 Cellular Phone
Motorola C139 Ringtone problem
After you made the ring tone, go to Menu, Ring Styles.
Go to Loud Ring Detail, the go to Messaeg Tone. At the end of the factory installed tones, you will se the one(s) you made. Select it!
Apr 27, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Ring settings seem to change by themselves
first you cannot change what is there,just use the keypad lock it solve our problem....
Jan 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Sound settings
This may work
1- Turn off and back on,
2- Try "Ring Styles" under settings.
3- Try change "Loud Details"
Jan 02, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
