Question about Lands Phones
Bridge computer to grandstream (for phone power)
Trying to bridge computer to grandsteam (to get phone power). when I put in ip address given through the phone it brings me to westell 7500 modem instead. phone power told me shut modem off and take Lan line for grandstream and connect it to the wireless computer. When I do that I am offline so nothing happens when I plug in the ip address. Any help would be greatly appreciated. I have been trying to get my phone up for 2 weeks now.
    Problem Solver:
  • 13 Answers
"shut modem off and take Lan line for grandstream and connect it to the wireless computer " This clearly says 1.Shut off your modem 2. Use LAN cable to hook up your Phone Router to Lan port of your computer / or DSL Modem. READ the Instructions carefully or call support.
Vonage has a phone adapter that hooks via LAN cable to DSL Modem. but it can also be used in a pc directly when extra LAN port is available or ICS is enabled. - Kepp it simple..
Posted on Apr 08, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
I have the same problem Did you get an answer. Verizon wants I should talk to there expertise tech for a fee. Did anyone try it?
Posted on Feb 10, 2010
Factory Reset Grandstream GXP 2000 w/o using the menu?
From the Granstream User Manual (Page 44):
Restore Factory Default Setting
WARNING: Restoring the Factory Default Setting will delete all configuration information of the phone.
Please backup or print all the settings before you restoring factory default settings. Grandstream is not
responsible for restoring lost parameters and cannot connect your device to your VoIP service provider.
INSTRUCTIONS FOR RESTORATION:
Step 1: Press "OK" button to bring up the keypad configuration menu, select "Config", press "OK" to
enter submenu, select "Factory Reset" (Please refer to Table 5-1 of keypad flow chart)
Step 2: Enter the MAC address printed on the bottom of the sticker. Please use the following mapping:
0-9: 0-9
A: 22 (press the "2" key twice, "A" will show on the LCD)
B: 222
C: 2222
D: 33 (press the "3" key twice, "D" will show on the LCD)
E: 333
F: 3333
Example: if the MAC address is 000b8200e395, it should be key in as "0002228200333
395".
NOTE: If there are digits like "22" in the MAC, you need to type "2" then press "->" right arrow key to
move the cursor or wait for 4 seconds to continue to key in another "2".
Step 3: Press the "OK" button to move the cursor to "OK". Press "OK" button again to confirm. If the
MAC address is correct, the phone will reboot. Otherwise, it will exit to previous keypad menu interface.
https://www.grandstream.com/products/gxp_series/general/documents/gxp_usermanual_english.pdf
Apr 03, 2014 | Grandstream GXP-2000 IP Phone
OTC Wireless Bridge
Alright I have good news and bad news the good news is: if you remove your IP Phones the setup will work again. Once it is working plug in one of your IP phones with Laptop plugged into the bridge. Once the IP phone is connected test if the Laptop remains connected. The use another Laptop with crossover cable to connect it to the IP Phone one question (is the IP Phone acting as a bridge between the OTC Router and the Laptop?)If it is it can pull an IP address if the OTC Router is a router and the IP phone is acting as a routed interface bridge. Once you get this to work duplicate the setup for the rest of you IP phones and laptops. BTW you do realize you are pummeling the router with RTP/UDP packets? I hope this helps Thank you, Shuttle83
Oct 05, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Does grandstream gxp 280 support vonage
Yes it supports.
SIP Account Name: Vonage
Phone Number: xxxxxxxxxx (enter your Vonage phone number)
Authentication ID: xxxxxxxxxx (enter your Vonage phone number)
Authentication Password: xxxxxxxx (enter your Vonage Authentication Password, this can be Provided to you by Vonage. Please remember that the password is case sensitive.)
SIP Domain: leave blank
Proxy Address: sphone.vopr.vonage.net
Port: 5061
Outbound Proxy: sphone.vopr.vonage.net
Port: 5061
Local Port: 5061
Register Timer: 3600
Codec: Auto
Pkt. Time: Default
Out of Band DTMF: On
-Karthik.
Sep 25, 2012 | Grandstream GXP-280 IP Phone
GrandStream GXP-2000 not booting
If both phones are showing the same symptoms then it probably means that your DHCP server is down or not configured properly. If the phones are on a separate VLAN and you have recently upgraded or replaced your network switch then it could be misconfigured as well - specifically it may require you to configure a DHCP helper address.
Dec 16, 2009 | Grandstream GXP-2000 IP Phone
Grandstream budget tone 200
Go to internet
Type your the ip phone address
type admin as password if you never changed it
That's it
Nov 04, 2008 | Grandstream GXP-2000 IP Phone
Static Ip with Speedstream 4200 Modem
I am assuming here with the way you have it set up your getting an internet connection.
what you saying i understsand mostly so i'll see if i can help you
first of all you have speedstreem modem that connects to you isp, this is assign your internet address from the isp if you paid for a static IP it would be in here, if not it's assiged by a dhcp from your isp company so if you if turn it off or have a power loss for anymore than 5-15min your ip changes.
now your modem then connects into your belkin router this as well as your modem it's prob set up as dhcp so it wants to issue each computer with an internal address of 192.168.0.X the reason for this is so it knows where to send the incomming information to what computer.
no matter what computer your using the address that goes over the internet will be the one assigned to modem from internet provider so if this need to be static IP to run your game server you will have contact your internet provider for an address.
but you may be confussing the issue a little, my suggestion to you would be:
1. go to your connections on each computer
2. right click on the lan connection choose properties
3. go to internet protocol (TCP/IP) then click properties
4. then click on obtain ip automatically and obtain dns automatically
this will remove the static windows address you may have put in.
try this and see if you can get you game or game server will work.
btw you may have to reboot your computers after this to get be sure to get the new address.
Oct 09, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Grandstream password recovery
if you have a password reset disk use that.otherwise
you must use the password recovery software
Feb 14, 2008 | Grandstream GXP-2000 IP Phone
Cannot Connect Gaming Console or Remote Computer to the Internet
1. Make sure the gaming or remote computer has a correct IP address with the same IP subset address as the wireless router or access point. 2. Turn the bridge off. 3. Turn the bridge on. 4. Recheck the IP address for the gaming computer or remote computer. 5. Turn off all network devices. 6. Power on the wireless router or access point. 7. Wait 30 seconds. 8. Power on the bridge. 9. Check to ensure the bridge connects to the wireless router or access point. 10. Power on the gaming console or remote computer.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Lands Phones Logo
126 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
