Question about Alpine CHM-S620 6-Disc CD Changer
Changer won't acknowledge discs
I put the disc cartridge in the changer and it sounds like it is checking each slot and the message comes up no cd. Is this something that can be repaired and if so how is it done?
  • notoncall Feb 23, 2009
    I have a CHM 620 6 changer in my trunk. Sometime it says "No Magazine" when I have one in and loaded.
    I have a 6 changer CHM S620 in my trunk. It got sometime reads "No Magazine" even though it's loaded and ready to go.
  • 199 Answers
Hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Posted on Mar 07, 2008
I have an alpine 6 disc cd changer in my car.when i turn on the cd button it says empty mag.,or sometimes it will click through the cds but not play any of them.unfortunately i cant find the model number of the changer. please advise
Posted on Oct 07, 2008
SOURCE:
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
Re-setting of cd changer
A couple of different possibilities here but this is a typical problem when it comes to the MB cd changers. Before ruling the cd changer bad, check the spring settings on the sides of the changer. Make sure they are in the 'H' position since it sits in the glovebox. The Mercedes cd changers don't have a reset button. 95% of the time its the cd changer that is bad when this scenario happens. Its caused by a linkage that gets knocked out of place internally of the cd changer. Also try not to use burned or homemade cd's as they can also cause the cd changer not to read the discs anymore.If your cd changer is brand new or a factory rebuild then the dealer should change it out no problem since MB cd changers are known for this problem. Also the version coding needs to done to configure the D2B fiber optic ring properly.
Aug 14, 2012 | 2001 Mercedes-Benz C-Class
When we put a disc into our PF-F906 CD changer, we get a 'no disc' message? how do we fix this
Label of the disc faces to your right and make sure the number on the display matches the slot you loaded.
Mar 05, 2011 | Pioneer PD-F906 100-Disc CD Changer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
Where is the changer fuze located on an autdiovox
It's not a fuse. More than likely it tried to load 2 discs into the same slot and jammed. That's one of the most common problems with shangers. If you pull the unit out of the vehicle and open the top you will see how it's jammed. Lightly move the CD towards the tray side, not into the cartridge, then plug the unit back in. It will reset itself and then you can eject the cartridge. Then inspect the cartridge for warps or cracks. You may want to replace the cartridge, they do wear out. Also, a good habit is to run a Laser lens cleaner thru the unit itself 3 or 4 times a year to keep the lens clean. It's really the only maintanance you can do. Hope this helps
Jun 26, 2009 | Audiovox SP11CDP 10-Disc CD Changer
Not working error 50 and 70
Clean the unit if possible. does the cartridge eject? if so, load it with a cd player cleaner, preferrably one that uses a cleaning solution. put it in tray slot 1. load and wait. try this a few times then try a good disc, one that is not scratched up. changers are hard on cd's. If it's still not working, below the cartridge slot there should be an inverted dimple that you can press with a ball point pen. This is a reset. It should have this button, I just can't remember the exact location if it's not right there. Hope this helps. If you have a spare cartridge try that as well, as they warp.
May 24, 2009 | Pioneer CDX-P670 6-Disc CD Changer
Not sure what the problem is
Check the changer and see if cds are inserted correctly or if 2 cds are in one slot.
Dec 13, 2008 | Alpine CHAS-634 6-Disc CD Changer
Cd changer
The laser is dirty (happens alot in a car, especially the trunk) or damaged. a repair shop is your best bet.
Sep 11, 2007 | Car Audio & Video
Alpine CD Changer - won't read CD
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
Jul 30, 2007 | Alpine CHM-S620 6-Disc CD Changer
Alpine CHM-S620 6-Disc CD Changer Logo
1,048 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
