Question about Kenmore Oasis HE 27082 Top Load Washer
NO POWER MACHINE WILL NOT TURN ON , APPEARS TO HAVE NO POWER. MACHINE IS 34 ONTHS OLD.
  • cmcderm1 Feb 01, 2009
    I have the same problem, but worse, the lid is locked and my clothes are stuck inside!!!! I also had the F1 error on fill for 6months but have been bypassing it by restarting. The hinge on the lid is also broken. I agree it's a lemon and I will never by another Kenmore again. This was my first and last. I scheduled a repair with Sears, for $214 they'll come out and fix it and if it cannot be fixed, they'll give me $500 towards a new one. Also, the $214 warrantees the machine for an additional year. I hope the repair is successful the first time around.
    Novelist:
  • 126 Answers
Do any of the lights come on when you press the power button? if nothing comes on, then check the GFI outlet and see if it has tripped. quick check would be to unplug the washer from the wall and plug in a lamp. if the lamp doesn't work either, then the outlet doesn't have power.
either the GFI needs to be reset or the circuit breaker at the main panel needs to be reset. one GFI will control a couple of outlets that could be exposed to water (eg, bathrooms, laundry rooms, outdoors, etc). you'll need to find the one and hit the RESET button on the outlet.
if the GFI outlet is reset and still no power to the lamp, then find the circuit breaker panel (usually in a garage, basement or outdoors). open the door and see if one of the breakers has tripped. reset it (or replace if its an old style glass fuse) and see if power is now restored to the outlet cause the lamp now lights up.
if power is there to the outlet, but the washer still will not come on (and either work or display error codes), then one more thing to check is the connection at the machine/motor control unit (connector P13 at the unit). disconnect the washer from the wall outlet. to access P13, you'll have to remove the top console panel (its the one that has all on the buttons on it). its held on with 3 screws on the back that you can get to from the top (no need to move the washer out from the wall). loosen the screws, tip the the panel forward and lift it up. it will be connected to the computer board, so just move it out of the way. P13 will have the large black wires going to it. give it a push to see if its not locked in place. if you hear a "click", then it was not properly connected. you can remove it and reinstall it if you want, but make sure the machine is not plugged into the wall outlet.
put the console back together, plug the washer in and see if it works. if it still doesn't power up, then sounds like the computer board is dead and you'll need a new one. its about $150 from searspartsonline. replacing it is easy, but sears may pay $150 towards labor and $100 towards parts. give them a call.
good luck.
Posted on Feb 01, 2009
Fix the Error Code Sc 34-02
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Dec 16, 2015 | Konica Minolta 7155/7165/7255/7272/FORCE...
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
My chair is not charging. We are getting 34 volts
Hi. A voltage of 34 volts is way to high. Most chargers are limited to about 28.5 volts. You will quickly dry out your batteries at 34 volts. I would say your charger is very faulty.
You have probably already destroyed your batteries at that charge rate.
Are the batteries new or a couple of years old.
I serviced a machine last year, that, according to the owner, had been through 6 sets of batteries in 4 years. His charger had the same problem as yours.
Good luck. Neil.
Jun 20, 2010 | Jet 3 Ultra Power Chair
I can't turn my TV, have to power 15 or times for it to come one and it is also cutting out the sound intermittently for 2-3 seconds once the TV is on - it's approximately 8 yrs old, should it be replaced...
check your power switch it appears that your contacts in side your switch are fused with arcs, and are not making good contacts.
change that switch with a new one. a switch has four contacts switches in it, use a volt meter to check the 115 or 240 AC through the switch.
before changing that switch you have to check for dry joints on your power suppy section of your tv.
thanks.
Feb 27, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
27' vizon tv black screen
It seems to be a PSU (Power Supply Unit) problem. When you unplug it and replug, the screen comes on for a moment. That means that the capacitor does not hold charge for long. Open the back and look for bulged or burst capacitors on the module where the power cord meets inside. Replace the whole module if you can not replace the capacitor with exactly the same specs.
Nov 07, 2009 | Sanyo Vizon LCD-15A2 Television
I have a error code F-34-1 in konica 7055
Hello sir; You need to reset, the procedure as follow; power off the machine, hold down 2 & 5 while you power on machine,then chose 1 soft switch setting, then dip switch 3 bit 1, 2, 3, 4 set to 0. then turn power off and back on.
Sep 26, 2009 | Konica Minolta Office Equipment & Supplies
What does the code Sr mean on a maytag neptune front load washer
Technical Manual say "System Relay Failure"
Diagnostic Code 34
Jul 16, 2009 | Maytag MAH8700A Front Load Washer
How to change turn-off time from 20 minutes?
Power Save mode allows your machine to reduce power consumption
when it is not in actual use. You can turn this mode on and select a length
of time for which the machine waits after a job is printed before it
switches to a reduced power state.
1 Press Menu until System Setup appears on the bottom line of the
display and press Enter.
2 Press Enter when Machine Setup appears.
3 Press the Scroll buttons until Power Save appears and press
Enter.
4 Press the Scroll buttons until the time setting you want appears
and press Enter.
5 Press Stop/Clear to return to Standby mode.
Jun 28, 2009 | Xerox Phaser 6110 Laser Printer
Kenmore Oasis HE 27082 Top Load Washer Logo
326 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
