"NTLDR is missing" message and don't have recovery discs and hitting F10 does no good. Windows XP Home. Tried ideas found on intranet, but can't get to prompt which is needed for most ideas.
You can download and burn the Hiren Boot CD to fix this. However in most cases you'll get another error. Re-installing the operating system is your best option. If the recovery console doesn't work (F10) then you may also need to replace the hard drive. If you don't have the recovery discs. You can order them from HP.
SOURCE: Windows Xp Home edition Installation
Hi tross202;
Is that an original XP home edition installer? You may try another cd installer if you can secure one.
SOURCE: after using recovery disc for windows xp there is no sound
You need to update the sound drivers, Find out what sound card you are using and search the web for the drivers by either typing your motherboard model or your computer model. Use search functions to help you find what you are looking for. I hope this helps. You might want to provide more info on the devices attached to your motherboard. Use device manager for more info.
SOURCE: file missing or corrupt
You could always use Ubuntu either temporarily or permanently. It's an Operating System based on GNU/Linux and is completely free, and in a lot of people's opinions it's better than Windows. You can set it up to run on a seperate partition and choose which OS to run at boot, or you can format the drive and just install Ubuntu which will automatically run at boot.
check it out here:
What is Ubuntu?
Read about it, get the free download, burn it to a CD-R and reboot to install. The installation is straight forward, and the new GUI in 9.10 is simple to learn for a new user. Most drivers are automatically configured if not all, already. :) Hope it helps
Testimonial: "I will try this solution as my last resort since I am not sure if he would be ok with this, but it is very helpful to know!"
SOURCE: I need a layout diagram for an HP 085Ch
if you are planing to connect the front panel cables..is better if you send me some pictures in order to asist you better...jesus_andre20 at /////h///o////t///m/////a///i////l/////.////c/////o//////m///
First make
sure there are no disks in any of the drives cd floppy and usb Computer is
booting from a non-bootable source.
Computer
hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and NTDETECT.COM file.
Misconfiguration
with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME
computer that is using FAT32
New hard
disk drive being added. Corrupt boot sector / master boot record.
Seriously
corrupted version of Windows 2000 or Windows XP.
Loose or
Faulty IDE/EIDE hard disk drive cable
Failing to
enable USB keyboard support in the BIOS.
Many times
this error is caused when the computer is attempting to boot from a
non-bootable floppy disk or CDROM First verify that no FLOPPY DISKS or CD is in
the computer, unless you are attempting to boot from a diskette
Test all
power and data leads that attach to your hard drive including IDE,SATA
if ita flat
40 pin ribbon type it will be the first to fail.
The leads
from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust
free connections and are not faulty
Make sure
all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure
connections
Computers need power and data to travel through every
working device and continue its cycle and have an end so any faulty leads will
end up with a computer error
also
When NTLDR is missing from
your operating system it means that there is a problem with your boot loader, a
bootstrap process that begins when you turn on the computer.
A missing NTLDR means that
your computer cannot boot to the operating system.
This issue is only a problem
on computers running Windows XP or previous operating systems as Windows 7 and
Vista don't utilize NTLDR.
Fixing the missing NTLDR is
relatively easy so long as you have your installation disc.
Locate your Windows XP/2000
installation disc and place it in your CD/DVD ROM drive. If you don't have this
disk, then you cannot proceed further.
Restart your computer.
When the computer restarts
press any key on your keyboard when you are prompted, "Press any key to
enter setup."
Most computers are configured
to boot to another device other than a hard drive.
Since the Windows XP/2000
installation disk is bootable, you should see the prompt.
However, if you don't see the
prompt you may need to change your boot priority in your BIOS. To do so, enter
the system BIOS by following the onscreen instructions upon startup.
Then navigate to the Boot
Priority menu and modify another device, such as a CD-ROM to boot prior to the
hard drive.
Then reboot your computer.
After you have pressed any
key, the Windows XP/2000 setup screen will appear.
After loading, press the
"R" key to repair the Windows installation.
The screen will appear black.
The computer requests which
installation you would like to log in. Generally speaking, press "1"
and "Enter."
If you have more than one
hard drive or more than one partition, the procedure may be different.
You must know which hard
drive or partition your Windows operating system is installed in.
You are subsequently prompted
for a password.
If you haven't set up one up,
you can just leave the query blank and press "Enter."
The phrase
"c:\WINDOWS>" and a blinking cursor subsequently appear.
Type "copy d:\i386\ntldr
c:\windows" (without quotes), where "D" is the letter of your
CD/DVD ROM drive (your optical drive may be different, especially if you have
more than one).
Eject the CD from the drive
and type "Exit" (without quotes) to restart your computer.
The NTLDR file will be copied
from the installation disc to your hard drive.
or
If you've started your Windows XP computer and you see an error message
to the effect that the "NTLDR" file is missing or corrupted, you've
probably also noticed that the computer refuses to boot any further.
This is because the NTLDR
file is an integral part of the boot process and needs to be restored before
the boot process can proceed normally.
Insert your Windows XP disc into
your computer.
Restart the computer and
press any key on your keyboard when the message prompting you to do so appears.
Press the "R" key
to open the Recovery Console and then press "1" and "Enter"
in order to select your operating system.
Type in your Administrator
password (if needed) and press "Enter."
c:\" and press "Enter" and then type "copy
d:\i386\ntdetect.com c:\" and press "Enter."
Restart your computer and let
it boot up normally.
Since the NTLDR is freshly
restored, the computer boots up properly.
Hope this helps.
