Question about Toshiba Tecra S3 Notebook
WLAN card Toshiba Tecra S3 M740
Would like to install an internal WLAN card in my Tecra S3. Does anyone know the proper partnumber?
  • rob_jonkers Feb 06, 2009
    Problem solved
I cant install windows 7 on toshiba tecra s3 pts30e01p01dar
1) if you are installing from CD, test the o.system from the disk is NOT scrachted, or dust . Clean it.
2)if you are using the USB, see if the o.system is ok too, and you must formatted your hard drive very well, can be contained VIRUS or Old information, and the system ask that you must erase.
3) Try to install from your supplier TOSHIBA go to the web, and get the support and download the o.system free from them.or get some help from friend that know better your system.
Otherwise you must go to the repair shop computer for fix it.
God bless you
Sep 25, 2012 | Toshiba Tecra S3 Notebook
Windows 7 dirver
Was unsure about the model number of your laptop; is it the Toshiba Tecra S3. Information on how to find drivers and software is here. Unfortunately I do not believe support for Windows 7 is provided for this model.
All available information on the Tecra S3 here.
Please see this bulletin for information on how to use the Toshiba Upgrade Assistant when upgrading to Windows 7. This program may help provide a definitive answer as to whether it would be possible to upgrade.
Dec 31, 2010 | Toshiba S3 Graphics SuperSavage/IXC 1179
How to install internal bluetooth card in toshiba tecra M2
  • Hi, there are two areas to view; the first, go to and Type in the Search window Bluetooth, next if you have the "Toshiba Application and Installer software?" Type: toshiba, if the (TAI) software appear in the search, open and "Install" Bluetooth device. If the solution helped, "rating it is appreciated, thanks"
Mar 11, 2010 | Toshiba Tecra M2 Notebook
How to remove built in wireless card on Toshiba Tecra M2v-S330
Assuming you are in XP:
Start in safe mode and either try to fix your Configuration (did you installed anything conflicting with you WLAN card?) or simply disable the card from your configuration in Control panel, system, Hardware tab, Device manager
Check if an updated driver exists for your card: latest SP3 is sometime conflicting with older device drive.
Let me know if working and do not forget to rate the solution
Jan 11, 2009 | Toshiba Tecra M2V-S330 Notebook
Driver required NETWORK CONTROLLER for Toshiba tecra m2
i can not find the wireless lan driver for tecra m2
Oct 05, 2008 | Toshiba Tecra M2-S730 Notebook
Toshiba Tecra 9100; "output device error" message
No sound? The only solution I've found is to get a USB headset like the Logitech USB Headset 20. I have had this same problem with my Tecra 9100 for almost 6 months. I tried on a pair of USB Headset and it works! because it bypasses your internal soundcard. The downside is that if you have a great pair of speakers on your laptop, then it's kind of a waste that you can never use it. But at least, with this, you can now listen to CDs and chat on the internet
Oct 22, 2007 | Computers & Internet
Toshiba Tecra S3 Notebook Logo
125 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
