Question about Neff R4381 Electric Commercial Dryer
How do you remove the front panel of the neff R4381X1GB dryer?
Have lost the instructions and need to clean the main filter.
On the right handside, there is a button that sticks out, press it down. If filter is heavily blocked, you will need to pull the panel a bit to dislodge it but the latch for the front panel is the button on the right handside.
Posted on Jun 14, 2009
Our NEFF r4381x1gb/4 will not run a full cycle,
I would guess you need a new controller .(timer)
Jun 19, 2016 | Neff Dryers
Empty water resevoir light keeps coming on
Hi Lisa,
Sorry, this isn't a solution! I've been investigating my wife's dryer which is the same model with the same fault exactly, by symptoms. An electrician friend has also taken the back off and suspects that the heater element has burnt out, but I don't see how that links to the fault as originally seen. Did you find an answer by other means or did you have to replace the unit - in which case did you manage to find a suitable model? Ours needss to take the kitchen cabinet door fittings, but I'm told John Lewis aren't doing this model any more.
Chris Corry
chris_corry@tiscali.co.uk
May 11, 2010 | Neff R4381 Electric Commercial Dryer
Maytag performa Keeps blowing Thermal Fuse. Vents are clean. Cleaned entire system. Seems to heat up as soon as dryer cuts off.Changed control thermostat as well. Can get one load and replace fuse.
something is still plugged with lint,if the vent line is long blow it out with a leaf blower to clean it out,you have to clean out the duct that the lint filter slides into,if the filter is on top remove the vent line,remove the back panel,remove the lint filter and the two screws in front of it and remove the four screws and clean out the duct,if the filter is in front take off the bottom panel,remove the filter and clean the duct,also vac out the inside of dryer where the motor is,when the dryer gets to hot the thermal fuse pops as a safety so you still have a block somewhere
Mar 19, 2010 | Maytag PYE2300AY Electric Dryer
KA dryer has been running without a lint filter. Other owner. I need to know how to take off the front and back panal to clean inside due to fire hazzard. Mdl # KGYE800TWHO . Need schematic drawing. I am...
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Next, place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the lower panel. This will release the lower panel and give you full access to all the main components and most internal areas needing cleaning.
The only area affected by running with no lint filter is accessed by removing the rear panel. With rear off, the filter housing on the left will have several 5/16" hex head screws to be removed for access to the blower wheel and housing interior. With screws removed go to front and insert putty knife in the seam between the top and front panels about 4 inches in from both sides. Lift top at same time and raise when disengaged.The filter housing can now be moved sufficiently to vacuum the interior from the rear removing any large foreign objects first.
You have now cleaned all the dryer areas that need cleaning. Don't forget the airflow through the vent line of the house.
Reverse the above process to reassemble unit. Good Luck.
Wiring Diagram for your model is located at link below:
KGYE800TWH0 Wiring Diagram
Oct 02, 2009 | KitchenAid Dryers
Ariston Margherita 2000 AWD12 Advantage washer dryer filter clean
To clean filter, remove the lower plastic panel at front of washer.
Unscrew the pump filter cover anti-clockwise to remove and clean.
Please rate my fixya solution.
Thanks.
Feb 13, 2009 | Ariston Technologies Ariston AWD12 Front...
A Creda condenser dryer TCR2, it went off won't work at all now
There is a lint filter inside the front of the m/c.
A filter at the bottom left of m/c,undo catches to release it, remove it and wash out under running water to thoroghly cleanit.
.Remove water container at top left front , and empty.
Make sure air intake and air out lets are clear, one at front right, and one at rear of m/c.
You can download user instructions.
Goto;;
www.hotpoint.co.uk
Click on (after sales), click on download user instructions, and follow the guide
Plz rate my solution.
Thanks.
Dec 29, 2008 | Creda IWD12 Front Load Washer / Dryer
Need to find the filter as drum not spinning and water leaking
The filter on this model is in the main hose leading from drum to pump. It can be accessed by removing the panel at back of machine.
Dec 13, 2008 | Hotpoint Ultima WD72 Front Load...
Neff R4381 Electric Commercial Dryer Logo
855 people viewed this question
Top Neff Dryers Experts
gbob59
ray gallant
Nicholas Tipples
Nicholas Tipples
Level 1 Expert
Are you a Neff Dryer Expert? Answer questions, earn points and help others
