Question about Kyocera FS-2000D Laser Printer
Kyocera fs-2000d printer
I have two of the above printers. Neither work number 1 when switched on shows on display : call service 0150:0000001
Number 2 shows, call service 0150:0003284
can yoy help me to overcome this.
martin gritton.
    Genius:
  • 2,120 Answers
A KYOCERA-MITA technician has to upgrade the firmware.
Posted on Jan 31, 2009
Kyocera FS-2000D shows call service 7410:0130324
7410 is an error (all numbers following : is the number of pages printed.
- indicating the Drum Unit is not installed properly or you have a defective curcit board. Tyoically it is drum drum is not fully seated.
If you open the door on the left hand side of the printer, where your waste toner container goes and press firmaly on the drum which is loacted behind the waste toner container and close the printer backup. If the drum is properly seated the error should close.
I hope this is helpful,
Shawn
Feb 07, 2011 | Kyocera FS-2000D Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
How can i see the serial number or how do i reach it cause i cant
press manu button then go to service then press right errow key goto status page press double enter it will print around 5 or 6 page in second page in down you can find the serial number or else see the back side of the printer it should stikared.............
Nov 05, 2009 | Kyocera FS-2000D Laser Printer
Kycocera fs2000d
Sounds as if the fuser unit has a damaged gear.You will need to call out a technician.
May 01, 2009 | Kyocera FS-2000D Laser Printer
HI My Kyocera FS-6020 comes up with the call service number 4200:0019564 number! does anyone know what this means thanks
This error code means that the Laser unit in the machine has failed and will need to be replaced.
Mar 24, 2009 | Kyocera FS-2000D Laser Printer
Regardin kyocera FS-2000D
The files called 2000sys.zip & 2000_eng.zip I beleive, if that helps. I bet after you have updated the firmware, you will find the serial number absent from status page, muz get corrupted when the engine firmware chucks the 150 error, Just thought I'd say although is not norm a problem
Oh, It only ever does the 150 once, never if firmware is updated.
Nov 12, 2008 | Kyocera FS-2000D Laser Printer
Kyocera fe 2000d
Requires firmware upgrade and may have to use a kyocera service programme to recover page count and serial numbers.
Mar 12, 2008 | Kyocera FS-2000D Laser Printer
ERROR CODE 7410:0004729
Hi, switch off printer ,just open cover(door) on the left side of the machine and push Drum Unit in machine(to proper seat)
You have to hear "click" sound.Switch on printer.
Regards...
Mar 08, 2008 | Kyocera FS-2000D Laser Printer
Kyocera FS-2000D Laser Printer Logo
239 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
