Question about Archos Internet Media Tablet MP3 Player
How do I turn off Demo mode on Archos 5
I tried to update operating programme , now it is permanently in Demo mode, how do I disable Demo Mode please
  • 1 more comment
  • William Watson Mar 14, 2009
    Thanks that answer has done the trick
    I had the same problem with my ARchos 705 I was mucking about with it and pressed the DEMO Mode and your answer did the trick, many thanks your a life saver
  • Anonymous May 19, 2009
    jak wy????czy?? tryb demo w archos5?
    Problem Solver:
  • 8 Answers
Click Tools -> Settings -> Firmware and Plug-Ins and click stop demo Firmware (Mine is not activated and this may not be there).
Posted on Feb 03, 2009
It is stuck in demo mode how do I fix the problem
SELECTED PRODUCT: (change your search)
How to disable the demonstration (DEMO) mode.
Article ID: 42707 ' Last Updated: 03/11/2014
Sony® stereo systems will enter the DEMO mode the first time you power on the system or if you do not operate the unit shortly after turning on the power to the system.
To disable the DEMO mode, while the stereo system is powered off, press the DISPLAY button repeatedly until the demonstration display disappears.
  • Depending on your model, some units have a DEMO button that is used to disable the demonstration mode. If your unit has this button, with the power to the system off, press the DEMO button until the display disappears.
  • If applicable to your unit, setting the clock on your stereo system will also disable the DEMO mode.
  • Using the buttons on a supplied remote control will not disable the demonstration mode.
If model-specific information is needed to complete any of these steps, refer to the operating instructions supplied with the product. Manuals, Specifications and Warranty information for your Sony product is available online.
May 27, 2015 | Sony Audio Players & Recorders
How to Disable Philips Magnavox Demo mode
  • Many people are annoyed about demo mode coming out of nowhere and causing problems with many Magnavox televisions there is a simple process which will allow you to disable the demo mode.
  1. Television must be turned off But remain plugged in
  2. First You must place both your fingers on the VOL + and VOL - buttons on the television.
  3. Then Turn on the television while still holding the volume buttons in for about 6 seconds..
  • The demo mode will now be disabled, Some televisions may turn off after demo mode is disabled just use remote to turn television back on or use programme up and down button on television to turn it on.
  • This will work even if you don't have the original remote as it requires no remote at all its a simple process and it will work with nearly all models of Magnavox televisions.
on Aug 01, 2010 | Philips Magnavox 27MS343S 27" TV
My Tablet is stuck in Demo Mode just came on one day and now won't shut off it has a blue line at the bottom that says Demo Mode. How do I get rid of it?
try this,,,settings>storage>apps> demo video> disable
or this,'
Tap on Apps in home screen - Settings - Storage - Internal Storage - Apps - Scroll down and Identify "Demo Video Application" under the apps list .
Tap on Clear Cache and tab on "Disable", Ignore the warning message.
Note: Cust may see the "Demo mode" icon in the homescreen, however it wont bringup Demo Video
May 22, 2015 | Acer Iconia B1-710
Demo mode will not shut off in lower left corner
Please follow the below mentioned procedure to disable Demo Mode in Acer Iconia Tablets.
How can get out from Iconia A1 810 DEMO Mode
Nov 10, 2014 | Acer A1-810-L888 8-in 1024x768 LED...
Disable demo mode on nook hd+
Go to settings, then device information. While pressing the volume up button, tap above the volume bar and a popup menu will appear. Uncheck "Enable demo mode", then power down your Nook. When you restart it, the Nook should be in regular mode.
Nov 01, 2014 | Nook HD+
Can't get out of demo mode Westinghouse oven WVE916SA!
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
Demo mode on ipad 3
Disabling store demo mode If you consider installing the configuration file included below make sure you understand how to disable this mode first.
Mobile configuration files are used to configure phones in enterprises. Apple provides an app called the iPhone Configuration Utility (IPCU) to install and remove configurations. To disable store demo mode:
  • Use IPCU to remove the configuration from the phone
  • Reboot your device
Dec 27, 2012 | Apple iPad 16 GB 3G Tablet PC
Feature demo
The feature demo automatically starts when
power to this product is switched off while the
ignition switch is set to ACC or ON. Pressing 6
numbered button during feature demo operation
cancels the feature demo mode. Pressing 6
numbered button again to start the feature
mode. remember that if the feature demo continues
operating when the car engine is
switched off, it may drain battery power.
• You cannot cancel a demo mode when the
front panel is open.
• The red lead (ACC) of this product should be
connected to a terminal coupled with ignition
switch on/off operations. If this is not done,
the vehicle battery may be drained.
Apr 26, 2009 | Car Audio & Video
Disable Demo Mode
If pioneer, try hitting the 6 while demo is running.
Apr 24, 2009 | Car Audio & Video
Ps3 always on demo mode
wht do u exatly mean by demo mode?
Jan 26, 2008 | Sony Playstation 3 (PS3) Console
Archos Internet Media Tablet MP3 Player Logo
1,742 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
