Question about HP iPAQ Connection Wizard (fa339a)
My internet connection was lost and can`t get it back. Network Connections says it is connected but no internet.
  • 1 more comment
  • Gerald Russell
    Gerald Russell May 11, 2010
    since it says connected, have you tried disonnecting and re-connecting? or deleting the connection and re-adding it?
    also, what OS? and what OS version?
  • smokeyone May 11, 2010
    what kind of internet do you have?
  • Colin MacKenzie Computer Force of Dawsonville
    how did you post this?
  • 15 Answers
SOURCE: IPAQ Rx 3715 Internet settings~ conectivity problem
I have a few thoughts.
Occasionally, for no apparent reason, the ipaq will "forget" your password. Try re-entering it.
The other option is to try a program called Kasuei Hitchhiker. It is a more powerful and easier to understand interface than the normal ipaq one. you can download it here.
http://www.freewareppc.com/communication/hitchhiker.shtml
Hope it goes well! I'll try again if this does not work!
Posted on Mar 01, 2008
LaptopExpert
  • 458 Answers
SOURCE: wireless network
First thing to do is look on your laptop... all the way around the sides, for a network switch... most newer laptops have one to switch your wireless on and off...
if none or is on:
go to your control panel/System/Hardware/Device Manager
and see if your network card is giving off an error or is working properly..
from there you can uninstall the driver and reinstall it, or update it..
if that still doesnt help... reset your router, refresh and renew your ip....(open Start/Run...type CMD... then type ipconfig /release.... then type ipconfig /renew
then click on the network icon in your control panel and try reconnecting to your network... readding your ssid and wep key if necessary...
hope this helps..
http://www.wnycomputerpro.com
Posted on Jun 09, 2008
SOURCE: Cannot connect to internet..network adapter
l had similar problem: my techy said that the firewall was stopping the modem from getting an automatic ip address - having said that he fixed it. sorry l can't offer more detail than that
Posted on Jan 06, 2009
Murphybanton
  • 2004 Answers
SOURCE: lost wireless system tray
Please run system restore to factory setting. that seem to be the only saviour.
rate this
Posted on Apr 13, 2009
SOURCE: internet connection
i had the exact same problem, all you need to do is do a recovery, you proberly won't need a cd because i didn't but even if you do then they are easy to make
Posted on May 13, 2009
Acer AspireOne safe mode setup
You are posting a docking station for a laptop. You need to make sure you Network Connections are good before attempting to use the dock with network.
More than likely you simply lost the drivers for the Network Interface Card,
Jun 04, 2013 | Computers & Internet
Lost wireless connection and yet it works with other computers... do I have an on/off switch on a Gateway 600y?
To turn the wireless emitter on or off in Windows XP:
1 Click Start, then click Control Panel. The Control Panel window opens. If your
Control Panel is in Category View, click Network and Internet Connections.
The Network and Internet Connections window opens.
2 Click/Double-click Network Connections. The Network Connections window
opens.
3 Right-click Wireless Network Connection, then click Enable to turn on the
wireless emitter or click Disable to turn off the wireless emitter.
Aug 17, 2009 | Gateway Computers & Internet
NEED HELP FROM ANY EXPERT OUT THERE! MAKE MY WELCOME SCREEN WORK!
Hi, you need to right click on your local area connection, then go to properties and uninstall the protocol from there.
May 30, 2009 | Acer Aspire T180-EA350M (AST180EA350M) PC...
In network connections i no longer have a local area connection.and i can only connect to the internet wirelesslly.
is this a laptop or desktop. Are the NIC's on-board or card slots? Could be either a motherboard or card failure.
May 29, 2009 | Gateway M360S Notebook
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
Internet connection failed
Try so see first the network connections in your PC. Go to your control panel of your PC select network connections then click the appropriate settings you want(just read the instructions then click). Having done this, and you have seen that there is no problem in your network connection settings then probably the problem occurs on the hardware connections. If you are using Cable modem, make sure the connections are fitted in, also with other type of internet connections except wireless connections. If having done this you still has the problem, it is now on the service provider has the problem, sometimes wired internet connections lost connections for a few minutes or more. Sometimes a blackout in the area of the service provider, so there is no power source that can be used to supply the network.
Mar 05, 2009 | RTO Eset NOD 32 Antivirus System 3.0 Full...
Internet connection lost
you have to go to the "Network connections" and set up a new network, your computer is probably defaulted to connect to the old modem and since it cannot find it it wont conect
Jan 11, 2009 | Acer Aspire 5630 Notebook
No internet connection
Internet connection solutions
  1. Restart the computer.
  2. Test the jack.
  3. Test the equipment.
    1. Try a different jack that you know works.
    2. Try a different cable that you know works.
  4. Check your computer settings.
  5. Renew your IP Address
    1. [x] Windows Vista
      1. Look for your Ethernet card:
        1. Right-click on My Computer from the Start Menu or on the desktop.
        2. Left-click on Properties.
        3. Click on Device Manager on the left side under "Tasks".
        4. Expand the Network Adapters and look for any yellow exclamation points. Make sure a card is listed.
        5. If there are exclamation points, or if there is no card listed, you need to reinstall the card.
      2. Set your IP address to configure Automatically (through DHCP):
        1. Go to the Control Panel in your computer (in the Start Menu).
        2. Go to Network & Sharing Center.
        3. Under "Network", go to Local Area Connection and select "View Status". In new window, choose Properties at the bottom.
        4. Scroll down "This connection uses the following items" list to Internet Protocol (TCP/IP).
        5. Select Internet Protocol (TCP/IP) and click Properties.
        6. Change to "Obtain an IP address automatically".
        7. After you have changed this, restart computer.
      3. Check to see if your network connection is on:
        1. Go to the Control Panel in your computer.
        2. Go to Network Connections. If you cannot see Network Connections, go to Network and Internet Connections and then go to Network Connections from there.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, double-click on the X to enable.
    2. [x] Windows XP
        2. Left-click on properties.
        3. Go to the Hardware tab and click on Device Manager
        3. Right-click on Local Area Connection and go to Properties.
        4. Scroll down the "This connection uses the following items" list to Internet Protocol (TCP/IP).
        7. After you have changed this, restart the computer.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, click on Local Area Connection and click "Enable."
    3. [x] Macintosh OS X (10.4 or "Tiger")
      1. Look for Network Cards:
        1. Go to the System Preferences panel from the Dock or Apple Menu.
        2. Open Network icon under Internet and Network.
        3. This shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Go to Show and then click on Built-in Ethernet.
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option.
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Then restart and change it back to DHCP to renew the connection.
      3. Set your IP address to "Configure Automatically using DHCP". Under the Ethernet tab make sure that configure is set to "Automatically". Click OK until you are back to the main System Preferences windows.
      4. Check your privacy setting
        1. Go to Sharing under Internet and Network in System Preferences
        2. Under Services everything should be unchecked.
    4. [x] Macintosh OS X (10.5 or "Leopard")
        3. The left menu shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Select Ethernet from the left menu. Go to Advanced.....
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option, "Configure IPv4".
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Click OK.Then restart and change it back to DHCP to renew the connection.
      3. Click OK until you are back to the main System Preferences window.
    // MAIN FUNCTION: new switchcontent("class name", "[optional_element_type_to_scan_for]") REQUIRED // Call Instance.init() at the very end. REQUIRED var bobexample=new switchcontent("switchgroup1", "div") //Limit scanning of switch contents to just "div" elements bobexample.setStatus('[x] ', ' ') bobexample.setColor('#674a80', '#3b5998') bobexample.setPersist(true) bobexample.collapsePrevious(true) //Only one content open at any given time bobexample.init()
  6. Make sure your computer is clear of all viruses, spyware, and adware.
Oct 03, 2008 | Computers & Internet
Internet connection
vodacom network unlock
Jun 02, 2008 | HTC TyTN II Smartphone
Lost internet connection?toasted router?
You will need to create your PPPOE internet connection on the router using your ISP username and password, access the router by opening internet explorer and type in the ip address of the router (example) > http://192.168.2.1 the router logon window will appear, use the username " leave blank" and the password "admin" -or- username "admin" with password 1234. Go into internet connections Select PPPOE connection enter your ISP username and password. restart the router and computer this should establish your internet connection. BPCS
Dec 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
HP iPAQ Connection Wizard (fa339a) Logo
216 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
