Question about Toshiba Satellite M105-S3004 Notebook
Toshiba Sattelite A30, random shutdowns & now cant open!
I have a Toshiba Sattelite A30. Just a few months ago it started doing random shut downs while im on the internet and now i cant even access the desktop.
I have tried many ways like using Safe mode and selecting diagnostic startup (which loads limited services). I can now access desktop but unfortunately its obviously still in safe mode.
Everytime i change back to normal startup mode though, i get this error :
"Explorer EXE : Application Error"
The application failed to initialize properly (0x0000142). Click on OK to terminate the application.
PLEASE how can i solve this problem?
Thanx for your help.
  • 1 more comment
  • azn_chick90 Feb 02, 2009
    Well i dont quite remember from the top of my head but what i do is, yahoo messenger and a recording program etc. but they both successfully installed properly.
    I was thinking maybe the application error msg occured because there were many programs and applications still on when the laptop suddenly shut down. can that be a cause though?
    Yes we do have a windows install cd and i've tried many times to start it up but unfortunately i still cant access my desktop, and the computer cant detect it either.
    Thanx
  • Report
    Report May 11, 2010
    taking a stab at it-- explorer is a main process of windows that runs the actual taskbar and desktop and notification area, so on. the fact that it's erroring each time means you may have a corruption in some windows system files needed to run your computer properly. this could have been from a crash, a power outage or surge, from a scandisk operation which found some incomplete files and fixed (deleted) them for you... whatever the cause, you may need to do a "repair", where you get your windows install disk, boot up to install windows with it off the cd drive, but select "repair the installation" instead of install. that will make sure you have all files you need, and will replace missing or broken files.
    The only other idea I have is that you installed a program that piggybacks off the explorer interface, like an alternate shell environment, some 3rd party toolbar or menu system, or utility which puts its hooks into windows itself. That program may be erroring out, or incompletely uninstalled, and since it was so intertwined with the windows shell, it's causing the error. This would be consistent with you doing OK in safe mode, but not OK with everything loaded...
    what have you installed lately before the error started?
    do you have your windows install cd?
  • Ibrahim Makki May 11, 2010
    Hi thereĀ
    did you tried to format your lap
BenQ Change language after i shutdown the computer ?
Using it since 2011 and the same problem started in few months. send back to claim warranty. they change internal board. was ok for few week until the problem back. never send back for warrranty as it took nearly two months to them to replace the piece. never going to get another benq product after this!
Sep 16, 2012 | BenQ V2420H 24" W Extra Slim LED Backlight...
I cant get my toshiba psaf3u to connect to wireless or dial up
Stay in touch with the built-in 802.11b/g wireless Wi-Fi. ... it comes with 1GB RAM you get the freedom to work with multi-window viewing of several applications at a time. ... After dancing around with Vista it just got worse1''cant open any files ... I recieved my Toshiba Sattelite a little over a month ago. ...
www.buy.com/.../toshiba.../206650181.html - United States
Dec 06, 2009 | Toshiba Satellite A205-S5804 Notebook
System gets shut down whe play any audio or video file
it might have a driver conflict issue...try to upgrade the sound driver of your model from the Toshiba website. Hope this helps
Aug 10, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Gateway Profile 5.5 Randomly Shuts Down
it seems, You can try after disabling firewalls. please let me know the results. I can guide you.
Jul 02, 2009 | Gateway Profile 4 All In One (MPN...
Toshiba Satellite Goes completley off! Black screen, NO POWER!
This problem is likely caused by overheating. The CPU reaches a temp to high and shuts the system down. When you try to turn it on the system is still to hot and it will not let the computer power on. You can try blowing out the fans and heat sink with an air compressor or can of compressed air. If this does not help the problem you may need to have thermal compound reapplied. If that does not fix it it will need a new heatsink/fan/
May 19, 2009 | Toshiba Satellite A200-0ET00X Notebook
Toshiba a30 laptop over heating problems
It is obvious that your computer shutdown because it is overheating. try to get a chill mat to place it under computer. you said that it does not shut down when is on battery??? do you play games when is on battery?....computers normally overheat during large processing tasks such us playing video games. Try to fans clear do not place your laptop ontop of your bed or anything that will obstruct the fan under computer.
See if that works
best luck
Apr 10, 2009 | Toshiba Satellite Pro A30 Notebook
Laptop shuts down when accessin the net
Scan your system from a good antivirus avast
http://www.avast.com/eng/download-avast-home.html
Feb 12, 2009 | Toshiba Satellite Pro A30 Notebook
C drive filled
It might not help but sounds to me like it updated a lot of updates. You might have to let it keep starting and rebooting till it has installed all the updates.How do you know it filled your hard drive?
Feb 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba A30 sound driver
You can download driver here. Just enter your model number and choose sound drivers.
Jan 16, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M105-S3004 Notebook Logo
210 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
