Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
Response to suggestion.
Thank you for the suggestion and we would remove the dishwasher if we could. Unfortunately we had a flood a few years ago and the floor was replace and built up another 12 inch. We have tried to remove the dishwasher but it won't quite come. So consequently I have tried to unclog from within the dishwasher and agree with you that it could be the hose close to the pump at the back. My husband has put the end of the hose which is in the basement ( where it is connected to the water source) in CLR but this doesn't go up to where the hose connects to the dishwasher. He is going to try and fill the hose with Clr and see if it then reaches. Any suggestions would be appreciated
  • 5,911 Answers
I was talking about the water inlet line going to the fill valve. The fill valve is located on the right hand side with the bottom panel removed. From the fill valve there is a water inlet line running into the SIDE of the dishwasher tub, NOT the pump in the back. The two pumps on the dishwasher are used for the cycling of wash water and/or draining the tub. Neither pump are used for the FILL cycle. Having an inlet line under the kitchen sink would make things easier. CLR would probably do the trick, but I'm afraid that gravity is going to keep you from accomplishing what you need to do.
Posted on Jul 31, 2007
SOURCE:
Flood switch will not reset
The lid seal is damaged and it lets water go through and collect on the flood switch which may be triggering F1.
You will have to replace the lid seal. It is item 8 on page 14 of this diagram.
Jul 27, 2012 | Fisher and Paykel 24 in. DS-603 Built-in...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Dishes leave food particles on the glasses - machine is only 2 years old. We use rinse agent - Cascade gel in the auto dispenser - we use jetdry dishwasher cleaning agen monthly - jet arms are not...
Recent changes in the law prevent soap makers from putting phosphates in dishwasher soap so they're not as effective as the were even a few months ago.  Unfortunately,  the solution is more thorough rinsing before loading.
http://www.appliance.net/2010/states-ban-phosphate-laden-dishwasher-soap-1988
Mar 03, 2011 | GE Dishwashers
My dishwasher is empty and last used, successfully, 2 days ago. The motor has suddenly started running as if to empty. the only way to stop it is to switch off the electric supply
This sounds like the anti-flood device is activated which would suggest a leak,if the tray underneath has water in it then a float switch would activate and the dishwasher would constantly drain out.You will have to remove the dishwasher and remove side panels and determine where it is leaking.If you tilt the dishwasher backwards to drain out the water then mop up the water then restart the dishwasher you may see with a torch where the leak is coming from.
Hope this helps.
Sep 19, 2010 | AEG Dishwashers
Anti flood system triggered Favorit 40660 dishwasher
The problem was solved by opening the machine and finding that the bottom "Y" pipe that has 3 inputs is of extremely poor quality and perforates with pin holes allowing a small amount of water to squirt out. This triggers the anti flood and error status lights flash. The outlet pump is activated and machine does not do anything. You need to replace this hose or like I modified it to work from a 32mm Y plastic junction available from most hardware shops. The wire clamps for this was replaced by "jubilee" screw tight clamps.
I worked on a table and also removed the "Brick" placed at the bottom for balance purposes by cutting the back plastic down with a saw. This made the job very easy...
Jan 13, 2010 | AEG 24 in. Favorit 40660i Built-in...
Doulbe Draw model receiving an F1 error message.
F1 indicates flood switch has been activated. I wouldn't advise you attempt repair on these drawers- they really require an expert to disassemble (I worked for F+P for 10 years!!). Depending on which model you have (DD603 or DD601v2), repair varies. 603 has a small circuit board that acts as flood switch- located in base beneath drawer- requires drawer to be removed for access. 601v2 model has polystyrene float that acts as flood switch-leaks usually caused by split lid seal(tricky to access- drawer has to be removed) In either case, a leak has occurred and activated flood switch. These drawers are very sensitive to detergents (don't use tablets!!), and the way they are loaded.
Would suggest you get service technician to remedy F1 fault
Aug 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Need to know how to re-set the anti-flood device
I managed to clean the filter inside the dishwasher and drain a little residual water. I then re-plugged in the appliance and the anti-flood device seemed to reset and I have n't had any problems since.
Jan 17, 2009 | Dishwashers
Standing Water in my Dishwasher
hi this is the electric pump thats in your dishwasher. its probably seized up.remove and clean it just might be dirty thanks the appliance doc,
Oct 15, 2008 | Kenmore Dishwashers
Miele Dishwasher G2170 scvi type hg03 dishwasher problem
Remove and check the "non-return valve" and make sure it's clean. It snaps out and in easily. See page 47 of the manual for this dishwasher.
May 20, 2008 | Miele Advanta G2170SCSF Dishwasher
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
113 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
