Question about RIM BlackBerry 8700c Cellular Phone
My blackberry 8700 will not come on completely. first - white screen comes up, following with the hourglass., then black screen comes up and LED ligt flashes red and then shuts off and then repeats.,.etc......
  • tazhall Mar 09, 2009
    My Blackberry 8700c does the same thing. the problem with the posted solution is that in order tp load new firmware, the device has to fully power up and that is the problem we are having....the device will not power up long enough for device manager to recognize it.
    Scholar:
  • 164 Answers
Hi Sam,
It is normal for Blackberry to load all its applications which takes few mins. However in your case the BB shuts off. I would suggest downloading the latest Device Firmware from www.Blackberry.com, and update your device with that firmware to your Device using the Desktop manager on your PC.
If not firmware then, check your device battery..
I hope this helps,
Thanks.
Posted on Mar 07, 2009
My bb screen is all white and I cannot turn it off as well. Please help
Hello
First of all what you need to do is to perform a reset on your BB by hitting ALT+RIGHT SHIFT+DEL your blackberry will reset itself. It will go black for about 2 to 4 seconds then you will see the famous blackberry hourglass. Be patient and in about 2 to 5 minutes your blackberry will reset.
ALT+RIGHT SHIFT+DEL can be used for continuous hourglass issues, JVM Error 200 "White Screen" to name a few.
If that does not work then you should perform a battery pull by just pulling out the battery out of the phone while it is on this is also a reset option.
Go to your service providers website, download the software from there, and then install it on your pc. Once done, delete the vendor.alx(xml file) file, open Desktop Manager (DM), connect the BlackBerry, and follow instructions
Apr 20, 2011 | Computers & Internet
The screen whites out n only way to get it back is take battery out n let it start back up
Hi there
Whenever your screen goes white again just hit the ALT+RIGHT SHIFT+DEL your blackberry will reset itself. It will go black for about 2 to 4 seconds then you will see the famous blackberry hourglass. Be patient and in about 2 to 5 minutes your blackberry will reset.
Try freeing up some space on your blackberry by deleting some unecessary files and do not run too many applications at once.
Oct 11, 2010 | RIM BlackBerry Curve 8310 Smartphone
There is an hourglass on the screen and the phone will not work.
Remove the back cover and remove and reseat the battery. Allow a few minutes for it to boot back to your main screen.
Then, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 14, 2010 | RIM BlackBerry 8700
Phone turns into a white screen with hourglass in the middle then shuts off. happens several times a day.
Hi it is because the BlackBerry Pearl 8100 smartphone cannot initialize the BlackBerry Device Software or there is a corrupt operating system file.
To resolve this issue, reload the BlackBerry Device Software on the BlackBerry Pearl 8100 smartphone.
To perform an installation of the BlackBerry Device Software using BlackBerry Desktop Manager version 4.5 to 5.0, perform the following steps:
1) Open BlackBerry Desktop Manager. 2) Connect the BlackBerry smartphone to the computer and open the BlackBerry Desktop Manager. 3) Double-click Application Loader.
4) Click Start under Update Software to start the installation process.
5) Type your BlackBerry smartphone password, if prompted, and click OK.
6) Select Options under Device Software Options.
7) Select the check boxes next to the names of the applications to be loaded, and then click Next.
8) Click OK > Next > Finish.
9) When the process has completed, the message The loading operation was successful will appear.
10) Click Close to return to the BlackBerry Desktop Manager.
I hope this information will be helpful to you.
Nov 21, 2009 | RIM BlackBerry Pearl 8100
Curve with white screen with hourglass and red light on
If the flipping hourglass stays for longer than 2 min our Blackberry may just need a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings.Download the Blackberry Desktop manager and run the application loader. Make sure you check to delete old applications in advanced tab. Carefully all you datat will be wiped.
Aug 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
BLACKBERRY 8700 HOURGLASS HELP
If your hourglass of death is occuring after a hard reset - Battery pull. It suggests a software issue.
You will need to reload your software, using desktop manager.
Mar 07, 2009 | RIM BlackBerry 8700g Cellular Phone
Hourglass comes on 5-6 times a day and screen goes black
You probably need to update your software to the latest version. You can download it from your service provider or from RIM: www.blackberry.com
Dec 31, 2008 | RIM BlackBerry Curve 8310 Smartphone
Reset blackberry 8700
my blackberry 8700g on/off ligt red
Apr 16, 2008 | RIM BlackBerry 8700c Cellular Phone
RIM BlackBerry 8700c Cellular Phone Logo
351 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
