Question about Dimplex Compact Electric Flame Stove Heater
The heater plug melted
The heater is only 3 months old.
  • Anonymous Feb 15, 2009
    My heater plug which plugged in to the remote box melted. Is there a recall on this?
Induction coil heaters draw very high amperage (12-14 amps) when turned on. If your outlet is worn or old the heater plug prongs will not have a good connection and the current will jump or arc from the outlet to the heater plug prongs. This arcing causes tremendous heat, enough to melt the outlet and the cord end. First thing to do is change the outlet.
Posted on Aug 27, 2009
    Problem Solver:
  • 33 Answers
You could have a bad outlet. The unit draws 1500 watts or 12 amps, if there is a loose connection anywhere it will cause resistance and produce heat. The heat produced from the 12 amp load can melt plugs and outlets. Have unit and outlet check by an electrician to be safe.
Posted on Apr 26, 2012
  • 188 Answers
Take it back to where you purchased it!!! Sound like a defect. Are call the manufacture of this heater, they should send you a new plug, or a Rep should come to see the problem. Also check on seeing if a recall on this heater????
Posted on Jan 31, 2009
  • 3 Answers
I have a ;asko 5141 model space heater and every time we plug it into a different outlet it melts the plug or the end of the plug on the heater. i've only had this heater for a hort time. what is the cause...
Have an electrician check the cord for a short circuit. It unit is under 3 years old it will be covered under Lasko's Warranty. Cord can be replaced, but it takes a special bit to take apart and know how to replace cord. You need a person you know who is Electrically and Mechanically capable for a safe repair.
Jan 04, 2011 | Lasko 5141 Ceramic Electric Heater
A plug melted while we were running a heater
1. Undersized plug. 2. May be heater runs with high current. 3. Loose wiring in plug.
Jan 02, 2011 | Heating & Cooling
Frost free freezer keeps frsoting up. It's a french door refrigerator with the freezer on the bottom. The vent is not blocked. The door has not been opened frequently. The appliance is only 9 months...
Sounds like a defective defrost timer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer
Also note that
Dirty condenser coils are not the problem. It's most likely the defrost timer or defrost heater. The heater should come on about 3 times per day to melt the ice on the evaporator coils. If the defrost timer is not turning on the heater or the heater is burnt out, the coils will freeze up......
Hope this helps
Jul 28, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
I have a Dimplex CS1205. Plug hot and melted outlet cover.
Many people think melting plugs and outlets are caused by the appliance that is plugged into them. It is very likly that the outlet is worn or loose or wiring connections are loose or the receptical is faulty. Arcing is a major cause for this condition and all of the above issues can cause arcing. This condition usually only happens when high draw appliances are plugged into the outlet. So a lamp could work fine in the outlet for 10 years then a toaster or heater is plugged in and a loose connection causes current to jump from the receptical to the plug prong which inturn causes tremendous heat.
Jan 11, 2010 | Dimplex Compact Electric Flame Stove...
My Heater Blower motor stopped working on my 2007 Chevy Suburban
you will need to check 3 places for this. 1 check the plug going to the blower motor for being hot and melting.2 check the plug going to the blower motor resistor for being hot and melting. 3 check behind the heater control head itself for being hot or melting.chevrolets are bad about these three places not making good contact and melting the connectors.
Dec 27, 2009 | Chevrolet Suburban 1500 Cars & Trucks
My dimplex night storage heater is not heating up, the power supply is fine. Is there a fuse or trip switch anywhere
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Dec 19, 2009 | Dimplex Heating & Cooling
Chemical smell
Might be Plastic part is Melting due to Heating Element or a Burning Wire might cause Such Smell.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 10, 2009 | Fahrenheat Electric Hydronic Baseboard...
Heater fan only works on high speed
usually when the blower motor gets old its starts to draw more current to run. which can pop fuses, burn out resistors and melt wires. also when you go to replace the resistor check the connector for signs of melting or burning you may end up having to replace that conector
Jan 06, 2009 | 1999 Chrysler Sebring
Dimplex Compact Electric Flame Stove Heater Logo
745 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
Iron
Iron
Mike Cairns
Mike Cairns
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
