Question about Emerson EWF2703 27" TV
Emerson color tv
My picture is now too bright and black and white. Is this even worth attempting to repair, is there something I can do myself.
  • Emerson Master
  • 12,061 Answers
The problem you describe is component failure in or arround the Horizontal Output Transformer section usually.. I would take it to the shop & get a "Quote" B4 proceeding.. there aint much ya can do yaself really without a Service manual etc.
Posted on Jul 31, 2007
Why does my KD-32FS170 32" Sony Trinitron screen have blue hues
If you turn all of the color out of the TV, the picture should be black and white. If that picture is not a true black and white picture, the TV will produce a color picture that has that behind it. It takes the proper mixture of red, green and blue light to produce white. This is something that is done inside the glass picture tube.
In your case, one color (blue is stronger) and the others are weaker.
It probably had not been used for a while. SOMETIMES, the weaker colors will get stronger with use. Adjust the brightness and picture controls to get the closest you can to a black and white picture, and then add the amount of color that seems right to you. Use the TV and hope for the best. It will improve, but 2%, 10%, or 50%; I do not know. The proper repair is to replace the glass picture tube, which is not an option at this time. So, turn it on, play games, and HOPE for the best.
Dec 04, 2014 | Sony Televison & Video
My emerson TV shows black and white pictures..what should i do?to make it color
Check the television settings http://www.manualslib.com/manual/47241/Emerson-Av50.html?page=30#manual
If Pal or NTSC these are the color systems if it is a mismatch to your broadcaster you won't get color.
May 03, 2014 | Emerson EWL3706 37 in. LCD Television
Some pictures are black and with only one color identfied
This company is very good and handles Fuji with excellence! http://www.teleplancamerarepair.com/Fujifilm_FinePix_S7000
As part of your repair they also clean the camera which is quite nice
Jul 01, 2010 | Fuji FinePix S7000 Digital Camera
Samsung HLN5065W only displays black & white picture
Hello,This problem denotes a defective color wheel, I would not suggest that you attempt to change it becuse of the risk of causing more damage. I would advise that you have the Tv repaired by a qualified TV technician, due to problems I have seen when repairing sets like this due to improper reinstallation of the color wheel.I hope this helps,Thank you,Shuttle83http://www.electron-age-technologies-llc.com
Jun 06, 2009 | Samsung HLN5065W 50" Rear Projection...
TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Dec 29, 2008 | Televison & Video
EMERSON EWL2005 20" LCD
Impacting the television can cause the video processor to come unmounted to the main board or the LCD panel inside to become disconnected. You need to take it in for repair.
May 24, 2008 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Toshiba Color Television....now picture is black and white
Good day.
The missing color issue can be resolved by resoldering the loose contacts in your units circuitry. Your unit is still worth to be fixed.
Response is highly appreciated.
chris
Mar 13, 2008 | Toshiba 32A50 32" TV
Sony Rear Projection TV Model # KP 53N74
I have had a similar issue with a Sony 52" circa 2001 tv. It was bad and then got better. The only problem now is that when I plug anything into the component 1-5 (but not 4) the screen is fuzzy. The DVD is plugged into 4 and it works fine. I tried plugging something else into that and it showed up in black and white. Very frustrating. Fancy TV if you only watch cable or a DVD. All other modes show up fuzzy. Sony recommended a tv repair place in St. Paul but they want around $400 just to look at it.
Sep 26, 2007 | Televison & Video
Constant changes in picture colors.
It is a 20" TV set and will most likly, im afraid to tell you, cost more to fix then it is worth. The problem is a bad Picture tube, an intermittant CRT socket or the video jungle IC is intermittant. If you want to invest in an estimate, check out first if it will go towards the repair, as then maybe you can get it fixed at a good price, as long as the picture tube is not the problem Good Luck
Oct 07, 2006 | Toshiba 20AF46 20" TV
Emerson EWF2703 27" TV Logo
203 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
