Question about Baumatic 18 in. BDW45.1 Built-in Dishwasher
Powers up , can't select programme
Does not beep when press power button to on , all the lights come on , does not let you select a programme.
2 Suggested Answers
  • 9 Answers
SOURCE: Baumatic BFD64SS Diswasher - power light on but can't programme
http://www.manualnguide.com/dl/12334/
Posted on Jan 25, 2009
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Indesit DIF04UK: Help with problem determination please?
Modifying a wash cycle in progress:
If a mistake was made during the wash cycle selection process it is possible to change the cycle, provided that it has only just begun: open the door, taking care to avoid the escaping steam, and press and hold the ON/OFF button; the machine will switch off with a long beep. Switch the machine back on using the ON/OFF button and select the new wash cycle using the SELECT WASH CYCLE button; start the cycle by closing the door.
Dado
Sep 08, 2014 | Indesit Dishwashers
I have been using a Sunbeam Model 5891 Breadmaker for over a year without trouble. Today I loaded the machine like always and selected the settings I usually set and hit go. Nothing happened. The lights...
The Sunbeam 5891 is a disposable type for there are no user-servicable parts.
Here's more:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 17, 2011 | Sunbeam 5891 Bread Maker
I have an Oster Bread Machine model 5839. The display and timer work but nothing else does.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You
Jun 15, 2011 | Oster Kitchen Appliances - Others
West Bend Bread Maker model 41056 does not start. When machine is plugged in, LED displays a time but buttons do not work and red light does not go on. (Pan was in machine and anchored.)
Power-Up/Start-Up Issues:
  2. Confirm the power source you're drawing from is live using a blender, toaster, etc.
  3. Plug the breadmaker in, unplug it, then plug it in a second time.
    1. Some models have a built-in off/on toggle power switch. Be sure it's turned on.
    2. Most models confirm power by making an audible beep when plugged in.
    3. Most models have a colored light and/or a lighted display screen that lights up.
    4. Most models require you press down on the Stop button until the unit powers up.
E. Some models require you press down on the Start button until the unit powers up.
F. Some models require you press down on the Select button until the unit powers up.
G. Many models require you select a baking mode by pressing the Select button before the pressing the Start button.
Q: In the end, were you able to confirm your breadmaker is receiving power?
No. Sorry to hear that. Have it serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the electronics by pressing down on the Stop button for 1 to 5 seconds. Note: A few models require you press down on the Start button instead. And even fewer require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. See reboot directions above.
Note: All breadmakers use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn during the kneading cycles, your timing belt is probably broken. You'll need to disassemble the breadmaker to visually confirm. The belt and pulley assemblies are located at the bottom of your breadmaker.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. 465ygbea
Jun 07, 2011 | West Bend 41053 Bread & Dough Maker
On ps3, when switched on, says hard drive corrupted, will restore. after a while trying to restore, same thing comes up again.
  • Turn off the PS3 console, if it isn't already.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Connect your controller to the console with the USB cable when prompted to do so.Turn on the controller. You will now have access to the PS3 recovery menu.Select option three which states "Restore File System: Checks for corrupt/missing system files." This option will identify and correct and corrupt files. Your PS3 should now be fixed. If this option doesn't fix your problems, you'll want to do a complete system restore and follow the next step.Turn off the PS3 console by holding down the power button.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Select option 5 which states "Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch." Be aware that performing a complete system restore will cause all data on the hard drive to be lost. This option restores the PS3 back to its original factory condition.
  • Dec 06, 2010 | Sony Playstation 3 (PS3) Console
    My playstation powers on and it show the ps3 symbol but after the wave stays on and my controllers cut off
    Ok here is a step by step process to solve your problem. Basically your system software has become corrupted. CAUTION! USING THIS METHOD WILL CLEAR YOUR SYSTEM OF SAVE GAMES AND ALL OTHER DATA!!
    Step 1. Turn your system onto standby (Red light on)
    Step 2. Press and hold the power button. It will beep as soon as you press it. Keep holding it until it beeps a further 2 times about 5 seconds apart. On the third beep the system will return to standby.
    Step 3. Press and hold the power button again. Again it will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. Let go of the power button.
    Step 4. The system will boot into the recovery screen. It will ask you to connect a controller via USB and press the PS button.After you have done this it will give you a menu.
    Step 5. Select option 5, "Restore PS3 system". This will erase the software on your PS3 and rewrite it. After it is done it will reboot and hopefully everything will be working again.
    Hope this helps
    Aug 05, 2010 | Sony Playstation 3 (PS3) Console
    Powers on-indicator lights light up, motherboard fan runs, but do
    try reseating the dimm ..
    I don't see a listing in the manual for 5 beeps as you describe
    Jan 04, 2009 | Lenovo ThinkPad X60 Tablet PC
    Annoying beep when wash cycle finishes on bosch classixx 1400 express
    Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
    Dec 06, 2008 | Washing Machines
    Bosch WFL 2872 washing machine has just started beeping (3 beeps) at approx 1 minute intervals at end of program until I turn machine off. washer is 3 years old & has never done this before - does it...
    A similar thing happened to mine. I think it starts when there is a power cut or something similar mid cycle. The solution (which you would never guess!) is the following:
    Select any programme - say 30 Cottons
    Press and hold any function button - NOT Start Signal will sound at varying levels - release button when it gets to the level that you want, off in your case. De-select programme Good luck!
    Jul 24, 2008 | Washing Machines
    Baumatic 18 in. BDW45.1 Built-in Dishwasher Logo
    27 people viewed this question
    Top Baumatic Dishwashers Experts
    Oloyede Monsuru
    Kolbrun...
    Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
