Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
No link to pc or Modem
It was working fine. two day back all of sudden stoped working.
But now
when connected to modem ethernet light in modem goes off.
when connected to pc "a network cable is unpluged" message pops up.
reset of ATA is performed but no use.
help is requested
  • 4 Answers
Gzfg
Posted on Jan 31, 2009
When I connect my modem to my laptop, all the lights come on except the pc link light. I have already unplugged it and reset it and it still doesn't work. What more can I do?
If the ONLY light not illuminated is your PC link light then that generally indicates a physical disconnect between the modem and the laptop. If you can get the PC link light to light up when connecting to any other device (computer, router, anything), then you are most likely looking at the ethernet jack on the laptop being burnt out. Otherwise, try swapping the ethernet cord. If a different ethernet cord does not resolve the issue and the PC link light does not come on no matter what the modem is plugged into, you are looking at a faulty ethernet jack on the modem.
Aug 17, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
Internet will stop working when laptop goes on standby
www.2wire.com I would be calling these folk in a heartbeat this should not happen and the fact is this is a malfuction with the modem myself. I have 2 of these modems without this issue.
May 22, 2009 | 2wire (1000-000057-000) Modem
Automatic installation failure
unless you were switching from DSL to cable Broadband, there usually wouldnt be much reason to rerun the software just because you got a new computer. when you ran the software the first time on the other computer, it was the router you were setting up, not the computer.
if the new computer is not getting internet when hooked to the router, try this.
1.turn off computer and unplug electricity from router and cable modem.
2. connect all ethernet cable to the right location. ethernet from modem to router goes in the non-numbered port, ethernet from your computer to router goes in numbered port.
3. plug in cable modem electricity first, wait for all its lights to come on like normal.(this part is important). the ethernet light on the modem (it might be labeled ethernet, link, pc link, or something similar) will not be lit, this is normal until you get to the next step
4. plug in the router electricity, give the router 2-3 minutes to get connected to the modem.
5. start up the computer, wait for everything to fully load and check internet again.
hope this helps.
Mar 21, 2009 | Siemens SpeedStream 2624 (SS2624) Wireless...
D-link dsl 320b lan light
Maybe it is ethernet driver
Apr 23, 2017 | D-Link DSL-2320B
D-link Modem Lan Light
Try to update the firmware of your modem.
Mar 04, 2009 | D-Link DIR-625 (790069292637) Wireless...
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
Lost internet connection
Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
Jan 06, 2008 | Trendware TEW-452BRP Wireless Router...
Light on my RCA cable modem goes off when I connect a wireless router (Linksys WRT54G). It was workign fine for good 12 months until I was cleaning under the desk and zoom the light is out. When I connect...
It sounds like the ethernet port has actually gone bad on the router. The light turns on when the device detects a phyiscal connection to another device. Your modem does not detect a connection to the router... But it does the PC. So you know the issue is with the router.
Jan 01, 2008 | Linksys Wireless-G WRT54G Router
Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
162 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
