Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer/dryer combo (Model# 41792702200)
Washer makes high pitch sound in spin cycle only.
I cannot remove the dryer drum from my Kenmore washer/dryer combo in order to remove the bearing, how do I do this???
Posted on Jun 05, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
During spin cycle it makes a high pitch whining sound and sounds like a button is loose in the tub
does it have a burning smell? is it belt driven? rather than direct drive. belt are known to emit a whinning pitch sound at times. could be bearings going out. and sometimes a pc of metal opr material can get stuck between hub and shell and make weird sounds?
Nov 08, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Spin cycle doesn't work
I don't know if this applies AT ALL, but if it does, then it would be an easy fix. If your washer isn't like mine was, then just ignore the following:
Start by popping the cap on the spindle inside the drum, it just has a plastic cap that pops off. With that cap off you can try turning the little doodad inside one way and then the other, and it should "ratchet," catching and making the spindle turn when you turn it one way, but freely spinning the other way. IF it freely spins BOTH ways, the pawl dogs are worn. This is what was wrong with mine, and the pawl dogs are cheap and easy to replace. To get to the pawl dogs themselves you would just need to loosen one bolt head under that cap, and lift the assembly out, and then the pawl dogs are on that assembly.
Mar 06, 2014 | Kenmore 24032\24036 Top Load Washer
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
I have a Kenmore Elite Oasis HE washer model #27092600. It is making a loud noise before and during most of the spin cycle when it is trying to drain. What would cause this. I have had this machine since...
Mine was making a high pitch sound, thought a rock got under drum.... now it stopped yesterday full of water ... and won't spin or drain. What can I do here at home to fix it?
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite spin cycle squeals
The clutch/transmission has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer Model #16852 make high pitch sound while spinning.
Is the high pitched sound that you hear during the spin cycle or just all the time during the wash? If it's during the spin cycle it's probably your transmission and the only way to fix it is to replace the transmission. It's only going to get worse with time and soon enough it will just seize up on you and nothing will work. A transmission for a Kenmore runs anywhere between 150 to 250 dollars. 150 if you can find a refurbished one. You can find them at any appliance repair shop. Kenmore transmissions are fairly common as it's a big name. I hope this helps you and if you have any other questions or need help with installing it let me know. I can give you an easy step by step walk through on how to install it. It doesn't take too long. Good luck to you.
Jan 05, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Stacked Washer/dryer
possible the bearings are going. place yor hand in the bottom of the drum and run the drum around and feel the bearings for any wear/ noise/vibration. alteratively the bearings in the motor could have gone and spinning with the belt removed would prove this.
Jan 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24032\24036 Top Load Washer Logo
426 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
