AOT30PMAL maintenance manual
Looking for a maintenance manual which has the wiring diagrams and LED blink codes for the Fujitsu AOT30PMAL outdoor unit.
notsomot
  • 67 Answers
SOURCE: Fujitsu AOT30PMAL inverter outdoor unit not working
Sounds like your compressor is seized or a start fault. If the unit is under five years old it should be under warranty. Call Fujitsu warranty out to have a look at it for you.
Contact details as follows
http://www.fujitsugeneral.com.au/contact.php
Sorry but either way I think your going to need a part there is very little that I can do unless your in WA.
Hope this helps
Posted on Jan 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: I am looking for the service manual for fujitsu 12rlq unit.
Low side pressure will be about 130 psig.
High side will be about 418 psig.
Posted on Apr 08, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
bobicehouse
  • 1524 Answers
SOURCE: I am looking for the outdoor AC unit wireing
Atta way.
Posted on Apr 27, 2009
  • 10 Answers
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
Posted on May 31, 2009
I have two flashes on the timer light of my indoor unit of Fujitsu Inverter ASU9RLS
Serial signal (reverse) error, at operation start up. operation led - off, timer led - 2 flashes, coil dry led - off, check wire between indoor and outdoor
Jul 10, 2015 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
Fujitsu ASY12RSE-W. Unit not working at all. Timer lamp blinking & operation lamp flashing twice
It's showing an error code for the outdoor unit no communication from the outdoor circuit board.
Jul 30, 2013 | Fujitsu 24C1 Air Conditioner
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
WMH24-1A 1st 2 lights ar blinking
http://www.sanyohvac.com/assets/documents/service/SM09KHS51.PDF
go to this website and see if this is the manual you are looking for.
http://www.sanyohvac.com/assets/documents/installation/ii09KHS51.PDF
One is the service manual and the other is the installation manual.
Good Luck.
Aug 05, 2009 | Sanyo 09KHS51 Ductless Mini Split Air...
Hope this helps
Jan 05, 2009 | Fujitsu 18C1 Air Conditioner
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
283 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
