Question about Canon PIXMA iP1600 Printer
My printer reads "off line" but all cords are connected and power is on...What can I do ?
    President:
  • 2,692 Answers
Error 931
In most cases this error has something to do with the printers LVPS (Low Voltage Power Supply ).
If the printer is connected to power surge, try to connect it to an outlet from the wall. Do an An AC power check - check the AC line voltage at the end of the AC line cord. If the Ac line cord is incorrect, replace the cord.
Also check if the cord is in good condition. if not, replace the cord. If you still get the same errror, you may need to replace the printers' LVPS.
For further assistance assistance please contact Lexmark Technical Support.
Feb 09, 2012 | Lexmark C750 Laser Printer
I do not have a power cord or usb where can I get them and where do they connect to printer.
You may get at Computer sales shop/Printer sales shop. Power cord is your power main line it must connect at left and USB must connect to computer and printer left..... thanks..
Aug 26, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My Lexmark C544dn laser printer just up and died - I had just put in new paper, hit print on my Mac and when nothing happened, I realized the machine was off. Yes, I checked the power cord at the machine...
Please try to do the following steps
• Check the AC line voltage. Is the line voltage correct? If not connect it to the correct line voltage
• Check if the AC line cord damaged. If damaged replace the AC line cord
• Is the LVPS cable correctly connected at JLVPS1 on the controller board? If not Reconnect the cable at JLVPS1
• Turn the printer off, and then on. Does the problem persist?
• Damage to the printer is possible. Be careful to touch only one conductor at a time, Rest the probe against the connector to steady it.
• Replace the LVPS - Low-voltage power supply (LVPS)
Please contact Lexmark Technical Support for further assistance.
Mar 26, 2011 | Lexmark C544dn Laser Printer
I have fax problem in my multi-function panasonic printer machine, all the power and rest functions are working other than fax, I am not getting the line dial tone when pressing monitor even the faxline is...
See Page 72 of the User Manual available here:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Multifunction-Printers/How-To-Guides/model.KX-FLB801.H#ts
I cannot hear a dial tone.
The telephone line cord is connected to the [EXT] jack on the unit. Connect to the [LINE] jack (page 21).
L If you use a splitter/coupler to connect the unit, remove the splitter/coupler and connect the unit to the wall jack directly. If the unit operates properly, check the splitter/coupler.
L Disconnect the unit from the telephone line and connect a known working telephone. If the working telephone operates properly, contact our service personnel to have the unit repaired. If the
working telephone does not operate properly, contact your telephone company.
L The power cord or telephone line cord is not connected. Check the connections.
L If you connected the unit through a computer modem, connect the unit directly to a telephone line jack.
I cannot make calls. L The dialing mode setting may be wrong. Change the setting (feature #120 on page 22).
The unit does not ring. L The ringer volume is turned OFF. Adjust it (page 23).
Hope this is helpful. ;)
Dec 10, 2010 | Panasonic KX-FLB801 All-In-One Laser...
Can't print and can't scan or copy LCD display ( jam 1 ) or ( no cartridge )
Usually when a jam occurs there can not be any functional traffic.
Disconnect data or printer connection cable and the power cord.
Open all access panels doors etc reseat all removable parts. Plug the power cord back in the printer and power it up see what happens. If clear then connect the the data line printer cord
Aug 26, 2010 | Office Equipment & Supplies
When printer is turned on it reads 256MB and that is it. No menu buttons or anything else will work. Never get ready light.
First, try to unplug and wait 30 sec. then replug the printer into the wall to try to reset it. Then, read below to see if there is a solution if the '256mb' display problem persists. Control panel display is blank No display message Cause Solution The printer’s on/off button is in the standby position. Verify that the printer is on. Fans might run while the printer is in standby mode (off). The printer’s memory DIMMs are defective or installed incorrectly. Verify that the printer’s memory DIMMs are correctly installed and are not defective. The power cord is not firmly plugged into both the printer and the power receptacle. Turn off the printer and then disconnect and reconnect the power cord. Turn the printer back on. The line voltage is incorrect for the printer power configuration. Connect the printer to a proper voltage source, as specified on the Power Rating Label on the back of the printer. The power cord is damaged or excessively worn. Replace the power cord. The power source receptacle is not working correctly. Connect the printer to a different power receptacle. Printer is on, but nothing prints Cause Solution The printer’s Ready indicator light is not lit. Press STOP to return the printer to the Ready state.
Jul 14, 2010 | HP LaserJet 4700 Printer
Vertical lines on printed, copied or in-coming fax
Since u have cleaned the flatbed and inside the cover,thats a nice move thou. Try the following steps that should resolve the issue,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
Regards,  raj_p5983
Jan 23, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Office Jet 6310xi All in One
Unplug the power cord from the All-In-One when there is still power in the unit also unplug the power cord from the wall outlet or surg protector, leave the cable unplugged for atlest 1Mins time.
Then connect the power cable directly to wall outlet without the surg protector and before connecting the power cord to the printer, press and hold the # and no 6 button in the All-In-One without releasing the keys connect the power cord and do not release the keys untill it shows as semifull reset.
Good Luck
Aug 21, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer not able to hook up to new Dell
your printer the g85 on the backyou will see below yhr bar codes where the power cord is four connections. looking at it from the back facing you on the far right is the power cord next to the power cord is the cord from the top lid second from the left i dont use this but i think it is the serial connection and far left connection is the usb cable the usb is the best on to use the two phone lines on what i call the leg or base far left remmber they need a special phone cord most cords only have two wires hooked up this on needs all four or it just want work right.hoop this helps
Jun 01, 2008 | HP G85xi All-Color InkJet Printer
Canon PIXMA iP1600 Printer Logo
20 people viewed this question
old marine
old marine
