Question about Evesham Axis PC Desktop
BLue screen BIOS problem
Getting blue screen on startup saying I need to up grade the BIOS as it's not fully compatable
  • oturns Feb 04, 2009
    I tried that but I couldn't find my Motherboard on the makers webstite :(
    Thanks for trying
How to remove a password off a computer
Posted on Feb 09, 2009
    Novelist:
  • 151 Answers
I) i would directly answer to ur question: upgrade BIOS, initially find motherboard make(company name), version and few other details and visit that company or motherboard website.
ii) they will provide BIOS upgrading software for your motherboard or what we call firmware upgrade.......
Note: sometimes u may get this software( u can download it) , otherwise u have to online update which            will do online BIOS update
Thanking you
M. Sridhar
Posted on Jan 31, 2009
How can i find my bios? i need to fix it because the blue screen is saying bios memory or cauche or shadowing things
Try powering off the machine then turning it back on. When it comes back on, immediately press the key to access your BIOS settings (it should be on the startup screen, if not try the F2, DEL, or ESC buttons)
Oct 03, 2016 | Neo M74S
The bios in this system is not fully acpi compliant
Guess your computer is not compatible with Windows 7. Reinstall windows XP run compatibility test from Microsoft
May 16, 2014 | Dell Inspiron 15 (N5050)
Dell latitude e5510 laptop got blue screen saying that a problem has been detected and windows has been shut down to prevent damage to your computer but it wont do anything ele's help any one
have you made any changes before the blue screen appear? installing a driver maybe? if you have,try to undone those changes by booting with Startup with last known good configuration (undo recent registry and driver change),use System Restore,or Roll Back device driver,Scan your computer for viruses
and Return BIOS settings to their default levels,go to BIOS by pressing F2 or del exactly after you press the power button and the screen show up
if it still in blue screen,that's probably that some of your system file is missing,and you need to reinstall your operating system
Please let me know if it's working or not,i don't like to abandon anyone,and thanks for using fixya
Aug 29, 2012 | Dell Latitude E5510 Laptop Computer (Intel...
I purchase compaq laptop model no CQ61-312TU they have a factory installed windows 7, i have fully format hard disk and installed windows XP but in Boot they show me Error, I check the BIOS setting , The...
you are getting blue screen because of compatibility issue. go into bios (press f2 on start up) and change from sata mode to ahci compatibility mode 'probably in the advanced section). you should then be able to boot from xp cd. remember to get your xp drivers from the hp website.
Apr 11, 2011 | Computers & Internet
Can't find updated ACPI Bios for toshiba satellite m45 s331. If found how to install? Getting blue screen Bios in this system not fully ACPI compliant.
I already explained in the other post ..The action required is either install a 3rd party raid and ahci driver ..and if you do not have the possibility ..just c\go to bios and enable the hard disk bus to work as ide..(disable ahci mode) I'm not sure how it will appear ..but you have to look under the bus mode..where the hard disk is seen ..It will appear as ahci enabled..and need to be disabled or ..will have raid mode enabled..and need to set it as native ..or ide compatible
Sep 08, 2010 | Toshiba Satellite M45-S331 Notebook
My thinkpad got stuck up while booting & i am getting blue screen. No further processing.
Is there any error message that you can see?What does it say?Or,is it just a blue screen and you can't see nothing? Blue screen can be caused by any hardware,software,poorly written device drivers recently installed and accidently shutting down of PC. If you can't see anything then take out the battery and press the power button for about 60secs.Startup without the battery first using the adapter and then see.If you still see the same blue screen then try the other options:
I want you to press F8,at startup, to bring up the advanced boot option and select "last known good configuration". Go to the BIOS setting pressing the DEL key at startup and select Load setup defaults [you might find that option in EXIT ]. Try removing any extra hardware attached like scanner,printer,pen drives etc.Later attach them again one by one and switching off and on the PC just to make sure which hardware is gone kaput. If you are able to startup the computer,use the SYSTEM RESTORE function to go back to previous date when your pc was working fine.This is to make sure you don't end up getting a blue screen at startup,again. The last option would be installing Windows OS. You can try and change the RAM sticks,if you have two then remove one n then start,do the same with the other RAM.
Jul 20, 2009 | Lenovo ThinkPad T61 Notebook
Wrong battery detected.
hmmm..interesting....you may need to download the system drivers, usually for bios or other utility programs. the compatibility issue with batteries, is based on the make/model being loaded into the listings from the sysadmin for your operating system.
www.hp.com
Feb 25, 2008 | Compaq Presario R3000 Notebook
Evesham Axis PC Desktop Logo
99 people viewed this question
Top Evesham Computers & Internet Experts
Lakshman P
Anwarul Haque
Anwarul Haque
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
