Question about Fuji FinePix 2800 Zoom Digital Camera
Power switch does not work and lens won't retract
I took a picture and then went to take another and realized that my camera was no longer working. My on/off switch will not work and of course the lens will not retract. When I turned it over I could hear a small part rattling around in the camera itself. Please help...I really like the pictures this camera can take.
  • wolfriver Jun 07, 2008
    Same problem here....was using it and turned it off and now it will not turn on even with new batteries. I also seem to have a small piece rattling around inside.
SOURCE: White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Posted on Nov 30, 2006
SOURCE: black screen
whats up with blackscreen?
Posted on Nov 18, 2007
  • 65 Answers
SOURCE: 'FOCUS ERROR'
If bought this at best buy and are still under your MFG warranty they can send it out to repair, or if you have their service plan, nothing you can do, this needs to be sent to a repair facility...
Posted on May 28, 2008
SOURCE: Camera turns off when I try to take a picture!
when turns off it means the battery is low.
Posted on Aug 07, 2008
zohail
  • 1223 Answers
SOURCE: My FINEPIX s1000fd fujifilm camera
pls update firmware issue will be resolved most likely and pls rate me fixya for help
http://www.fujifilm.com/products/digital/download/s1000fd/fupd.html
Posted on Apr 13, 2009
Canon power shot SD1200 IS elpf won't retract
This is a delicate operation but you can try this: tap the camera lens up on a towel over a hard surface (counter top or floor) while you expect the lens to retract as in turning off. It may be enough jarring force to get cams back in the helix that moved the lens. Hit it hard and flat. IF that doesnt work, try tapping the lens down while it tries to retract. I have heard that people get so frustrated with it that they slam the camera lens up on a desk and that fixes it!
Jan 30, 2018 | Canon PowerShot SD780 IS / IXUS 100 IS...
Lens error for coolpix l3. The lens won't retract and the camera won't work. took batteries out and put new ones in. nothing is working. is there a way to reset the camera?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 29, 2011 | Nikon COOLPIX L3 Digital Camera
My SD800IS was working fine while in the very hot/humid environment of Yap. I took it out of my air conditioned room and went to take a picture almost immediately. The view finder, the LCD image and the...
The foggy images and lens was due to condensation caused by the camera's surfaces being cold in a humid/moist environment. Usually this happens and goes away without issue. If you believe issues are continuing, consider placing the camera completely in a bowl of uncooked rice. The rice should help eliminate the moisture in the camera.
Hope this helps.
May 06, 2011 | Canon Cameras
Locked up
Try removing your memory card. I had the same problem and this worked. You might need a new card. Good luck.
Oct 01, 2008 | Gateway DC-M42 Digital Camera
Lens is stuckpartly open power button does nothing-won,t turn off
mine has done this and I have grabbing the lens and pulling it out at the same time as I turn it on. It is a pain but it now works
Jun 24, 2008 | Samsung Digimax L730 Digital Camera
I have a Canon Powershot S3 IS and I was looking at picture I had taken and the lens was retracted. I switched to the camera mode and the lens started to come out and hit my leg and stopped half way. The...
format ur memory card ....and replace the cells.....might work...contact the customer care for help ..they mightr be able to fix it ...
May 03, 2008 | Cameras
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
[Casio Exilim EX-S500] Lens will not retract
Nearly one year!
Then be quick and send it back under warranty - waste no time.
May 22, 2007 | Casio Exilim EX-S500 Digital Camera
Fuji FinePix 2800 Zoom Digital Camera Logo
53 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
