Question about GPS
Tefal quick cup- no longer heats water well
Only get luke warm water not hot
  • Anonymous Feb 23, 2009
    my tefal quick cup does not hyeat properly is there a reset function or a way to descale as thats my only thought.
  • Anonymous Apr 26, 2009
    Same problem
Press red button 4 times quickly should reset & poor between 85- 92 deg
Posted on Oct 06, 2009
  • krusebergare Aug 29, 2010
    It still only heats to about 50 deg
  • AnthB Sep 03, 2011
    the instructions specify descaling is a possible solution to insufficiently hot water. Worked for us 3 times each device, about every 4 months. The 4th time it made no difference, and I assume the element was broken. The descaling operation uses a button sequence and a litre of vinegar, and 30 minutes.
    Anyone know where to get a replacement element?
Rubberbit on windscreenholder doesn't stick to windscreen anymore.
clean rubber cup and glass.may need to dampen cup before sticking to glass
Apr 01, 2013 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
Hi, I have a Garmen Quest and the suction cup that mounts the unit to the wind screen has lost its seal, I need a replacement mounting base.
You can try retail stores such as BestBuy/Radio Shack. Or you can order a new one from the manufacturer. Although first try rubbing the suction cup down with rubbing alcohol to clean it and try it then.
May 04, 2011 | Garmin GPS
I NEED A WIRING DIAGRAM
what does a wiring diagram have to do with a cup holder mount? You might want to change how your question is posted to get people better able to help you!
Sep 16, 2009 | Garmin Golf Cart Cup Holder Mount For ...
Can't assemble suction cup mount that came with Nuvi 350
They fit tight together. Sometimes you need a little force.
Sep 13, 2009 | Garmin 010-10723-03 Suction Cup Mount...
If you are installing a gps on the dash how do you get the suction cup off?
try to get some air under that suction cup, either by pulling the rubber piece or try to lift it a bit with any pointer or finger
Aug 21, 2009 | Magellan GPS
Garmin nuvi 360 suction cup knob issue
If the end of the cradle has a ball,and the cup has
a round part, just push the ball in, yes it does go in hard but should be ok. If it makes you feel more
comfortable, you can put a drop of water on ball and wipe it around, once it dries, it wont slop around.
Apr 09, 2009 | Garmin 010-10723-03 Suction Cup Mount...
My problem is how to use the Dash moount disk for the Garmin 350? My real problem is getting the answer?
The dashmount disk has a sticky side that should be pealed and stuck to the dash - then use the windshield sticking cup to stick to the dash mount smooth side...
Jan 13, 2009 | Garmin Suction Cup Mount F/ Nuvi 350
Mounting tomtom 125 with disk
first ensure that the surface you are mounting to is clean use rubbing alcohol also make sure dis surface and suction cup are cleaned. remove sticker sticker peal from sticker on underside of disc place disc on cleaned dash surface. then place mounting cup onto disk this should hold quite well if not i would recommend getting the hard plastic type velcro and attaching to dis and suction cup that works well for me
Dec 27, 2008 | Tomtom (9K00.005) (636926011532) Mounting...
Garmin Suction Cup (Rubber)
Put a drop of dishwashing detergent and a few drops of water on the rubber and distribute it evenly before You mount it to the windshield. This mixture enhances the suction power and keeps the rubber soft. Repeat after 3-4 months! If You don't like the look of it on the outside of the window, put a smiley sticker on it! :-)
Aug 09, 2008 | Garmin Suction Cup Mount with 12V Adapter...
GPS Logo
1,343 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
