Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Dishwaher I have a whirlpool dishwasher and after i used it the last time the light on the panel flashes on air dry (control lock) When i try to clear it 2 or 3 of thelights flash at once.
    Problem Solver:
  • 6 Answers
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No HEat Dry" button for 4 seconds (or more).
Posted on Feb 25, 2008
Is there a reset button on the dishwasher? if so, where?
Not sure what type of reset you are after. Is the dishwasher not responding to any panel switches.
Is the keypad locked, i.e., is the control lock light on? Then press Energy Saver Dry button for 4-5 secs.
Are some lights flashing and dishwasher will not start? Have you tried to turn mains power off and back on?
If you think the controller needs a reset, you could try this sequence of keys within 7-8 secs.
hi temp scrub/ energy saver dry/hi tempscrub/ energy saver dry/ hi temp scrub/ energy saver dry.
If the reset sequence has worked correctly, then all lights should light up. Press Cancel to exit from reset mode. I am assuming you have a users manual. If not then download from here.
Please rate the solution if it helps your problem otherwise post a comment
Feb 18, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
AS PER DIRECTIONS FROM TECH, I PURCHASED AND INSTALLED A NEW CONTROL UNIT. THIS WAS BECAUSE MY WHIRLPOOL DISHWASHER GOLD GU2300XTLB3 QUIT WORKING IN ALL CYCLES EXCEPT SHORT CYCLE. PUT EVERYTHING BACK...
This is a common problem with Whirlpool washers.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 01, 2010 | Dishwashers
Our clean light flashes 7 times pauses and flashes 7 times again, we can not restart the unit whats could be wrong
This machine was made by Whirlpool and the flashing clean light is a common error code for them.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
or
Hope i helped you.
Dec 30, 2009 | Whirlpool Dishwashers
We have a dishwasher that flashes clean light on front panel and will not allow a new cleaning cycle. Mod GU3200XTPS3 TYPE 577-0
Make sure the control panel is not locked. If you press any pad while your dishwasher is locked, the light flashes 3 times and the selection is ignored. If the lock symbol is lit, press and hold HEATED DRY for 4 seconds. The light turns off.
If the control panel is not locked and the problem still occurs press the Cancel/Drain button to drain all water and clear all indicators. (It might take 2 minutes to complete this action.)
Jul 08, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Lock on light flashing
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Whirlpool Quiet Partner II dishwasher
I held down the heated dry button & it worked!
Aug 26, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
None of the Wash Cycles are Working
It's probably the touchpad - commonly used buttons quit working after a while. If not, then it's the electronic control board.
Mar 09, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Air Dry Button just flashes
that is the fault code indicating the button is stuck. the touchpad must be replaced. the lock light indicated two or more buttons activated at same time
Feb 15, 2008 | Whirlpool 24 in. DU920QWD Built-in...
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
405 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
