Question about Asko D1716 Built-in Dishwasher
Asko d1716 door switch
D1716 won't start. found door switch to be the problem. Door closes but does not engage the switch.Is this switch easily replaceable
  • 4,655 Answers
Below is a link to get a PDF of your washer. Cannot say if the solution is easy to resolve, but with the manual you have numbers and sources to get more assistance. Hope this helps,
Sea Breeze
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Posted on Feb 01, 2009
Crosley washer CFW7500KRO - Door lock won't stay engaged
Unfortunately I had the same problem and it ended up being the control board not sensing the switch being closed. Had to replace the control board
Sep 06, 2012 | Washing Machines
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
Dishwasher is loaded. It will not start.
Might be the door latch not engaging properly washer still thinks the door is open.
Dec 31, 2009 | Asko D1716 Built-in Dishwasher
No water running through on start up
it won't fill unless the door is closed & locked.
Check your inlet supply valve (mine is in the basement 10 feet away from the dw)
Jul 23, 2009 | Asko D1716 Built-in Dishwasher
How to remove main pushbutton switch from asko d1716 dishwasher
Hi I read your enquiry of how to remove the pushbutton swith.
You have to open the door, and remove the back panel of the door to release the front protecting cover panel. This is the only way to release the pushbutton. Do not forget to disconect the mains to avoid an electric shock.
Hope I have been of help
Nevd Fixya.
Feb 15, 2009 | Asko D1716 Built-in Dishwasher
Asko D1716 won't start
Ensure the water is turned on and the door is fully closed, make sure delay start is not set.....
if DW still won't start, I would begin by checking the door switch.
This link will download the owners manual for your unit. Click here
to download the manual.
Hope this helps.
Please take the time to rate this solution.
Jan 31, 2009 | Asko D1716 Built-in Dishwasher
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
Asko D3250 not working
If the first start button is blinking then there is a door error...the door switch is not closing... to repair
1) turn off the power at the breaker...
2 ) remove screws in the door T20
3) remove contol panel (slide up)
4) place wire tie behind micro switch on door latch...
5) replace door latch and door.
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 25, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Dishwasher does not "pause" (hault) when I open the door
it's the door switch gone bad or the wire going to it has fallen off.
Mar 01, 2007 | Asko D1776 Built-in Dishwasher
Asko D1716 Built-in Dishwasher Logo
318 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
