Blaupunkt Verona CR31 Car Radio Cassette player
SOURCE: Blaupunkt radio bp2770r4514872 cassette got code need to put in
I hope this helps.
copy and paste this link in to your web browser search window and click go.
www.davidsonelectronics.co.uk/code_entry.htm
SOURCE: Blaupunkt RDS car radio code needed
First make sure that the code has not been noted somewhere
within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be
removed from the dashboard (and if you are lucky, someone may have written the
code on the casing ) .
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL
plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL
CASING
There should be a 14 character number beginning with
BP++++++++++++ and also a model number beginning with
7 *** *** *** so quote everything you can find
Also quote the MAKE of CAR
SOURCE: Hi I have a blaupunkt cassette/radio in my car. I
ERROR 3 usually means that you have entered at least 7 wrong codes ...so make sure you have the correct code
To reset from ERROR3 leave it SWITCHED ON....UNDISTURBED until it automatically resets itself.
This can take several hours as the waiting time doubles after each wrong code
If you require help with the correct code then read below
If not then POST A BRAND NEW QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on
ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the
Serial Number
Otherwise try your Main Dealer ...........or take it into a
Decode Service who will plug in a laptop to read/recode the memory chip
(EEPROM). This takes a few minutes and shouldn`t be too expensive
Testimonial: "Thank you for the speedy answer! "
SOURCE: operating instructions for blaupunkt 300 in car radio cassette
ENTER A BLAUPUNKT CAR300 RADIO CODE
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of
your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of
Press Preset Button " 3" repeatedly until the 3rd Digit of
your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a
"Beep" from the speaker and
the radio should switch on
SOURCE: blaupunkt car 300 radio cassette problem
Leave it SWITCHED ON...UNDISTURBED until it automatically resets itself.
This make take several hours
Testimonial: "Thanks for that, i will try it and let you know if it was ok...."
