Question about Medion md40298 Notebook
Medion laptop 8081 wont recognise the hard drive until warmed up
Once turned on the laptop hard drive ticks for about 5 minutes and refuses to continue boot up, The ticking will stop and then will happily boot up all day and perform normally. Left overnight the same thing happens again.
Had 3 different hard drives in it ranging from 40 to 80 gb, all boot fine on the laptops they came from, a new bios battery fitted. Laptop has been completley stripped and rebuilt to check for loose connections. Tried every hard drive setting available in bios, tried all jumper permutations on the drive iteself.
Help!!!!
  • ivoratfortkn Feb 01, 2009
    yes it will boot from the cd, with no prroblem, but the hard drive is still not seen by the system. since my first post I have applied a warm blast from a hair drier to all the accessable vents on the outside of the laptop and gently warmed the whole motherboard up. result.. instant bootup, hard drive there and working fine, problem returns when cool. I think I may have a dry joint somewhere on the motherboard that closes up once warm.
    Looks like the long haul, I'll re-solder all the most obvious joints that could be stressed by hard drive removal, possibly around the bios battery and near sockets etc and hope for the best. will post the outcome - thanks for your time. :-j
    Problem Solver:
  • 15 Answers
Probably the mother board.if you boot from the CD will it boot?
Posted on Jan 31, 2009
  • Colin MacKenzie Computer Force of Dawsonville
    yes sounds like the MB. Well, at that point i just replace the MB and dont waste my time trying to find circuit problems. If the MB has been discontinued or just cost too much you will need to make a test jig so you run the board outside the case. Then proceed with warming up sections of the MB until it boots. You can then try and narrow it down from there. That would be very time consuming which if the laptop is yours maybe no big deal to you. But for a customer could lead to high labor charges.
Tick tick tick noise
Make sure there is no disc in the cd/dvd drive. make sure that fan vents are clear. Does this start when you turn it on, or when it warms up after about 5-15 minutes? The only stuff that moves in a laptop is a dvd drive, a fan or the hard drive (unless you have an SSD installed). The ticking noise may be one of these. The dvd drive is not an immediate problem unless you need it, NOW. The other two options are definitely important and I would not putoff getting this looked at, as they are internal and difficult to get to. If you are comfortable opening and working in a laptop that you are ahead of the game, but I can go no further, with so little information.
Nov 02, 2013 | Dell Inspiron Computers & Internet
My laptop doesn't recognise external hard drive
Most Windows versions:
Go to the diskmanagement (run compmgmt.msc) option Disk management.
Locate the drive and add a driveletter.
If the drive is not shown in the list, you need to check your USB drivers or connectors.
Jan 15, 2012 | Medion Computers & Internet
Windows xp wont start up in my acer laptop
Try tapping F8 as the computer turns on to get to the option screen, select last known good configuration, or then try safe mode. If that doesn't work, you can always press F10 to get to the recovery partition to completely reinstall the OS. Keep in mind though, this will completely wipe your HDD.
Feb 14, 2010 | Computers & Internet
Computer does not recognise, device making ticking sound
the ticking sound is a sign that the hard disk has crashed.
I would advise that you get another hard disk. Your present hard disk is having a bad sector.
Even if you are able to fix the problem, sooner or later, it would still disturb again.
So why not just change it once and for all.
All the best.
Jan 10, 2010 | Computers & Internet
Powers on wont post but dvd rom
Eject any disk from the DVD device.
Turn the computer off.
Disconnect the "data" and/or the "power" connectors from the DVD-ROM.
Turn the computer on, and see if it starts when the DVD-ROM is not part of your system.
If it starts, then your DVD-ROM needs to be replaced.
Dec 08, 2009 | Medion Computers & Internet
Getting ticking noise from the computer and it does not recognise the drive
The arm for the hard drive is probably bad. That is the ticking sound. The arm is loose and not reading the platters. If you have data that needs recovered from the drive, I wouldn't run it any more. Take the hard drive out of the case and find another computer you can put the drive in as a slave. You can try putting the hard drive in a freezer for an hour or so, plug it into another computer and try to get files off of the drive. This might work for a bit until the drive gets warm then you'll have to freeze it again. Freezing the drive might tighten the arm up enough to read for a short time to maybe recover files but the drive is probably toast.
Oct 01, 2009 | Western Digital 320GB MyBook External USB...
Car wont work after the initial warm up die down situation
Crank sensor or module. Check fuel pressure too.
Jul 03, 2009 | 1999 Pontiac Grand Am GT
Laptop wont turn on philips freevents x51
The most likely problem is that your Hard Drive has Died.
If you can readily access another Laptop HDD, try it and see.
Other than that, I'd say the Motherboard has decieded to give up the Ghost.
Just Remember, A Laptops life expectancy is 3 years, after that you are treading on thin ice keeping Important Documents on it.
Nov 27, 2008 | Computers & Internet
It takes @least 30 minutes to boot
It sounds like your computer is not recognising the hard drive. Go into the bios (keep pressing the delete key as your computer starts up ) and find 'hard drive auto select' and press enter to see if your computer can recognise the hard drive. Even if this works it sounds like your hard drive is on the way out.
1/ Make sure no floppy or CD in drives
2/ Check Hard Drive cable connections, both ends
3/ Go into BIOS and check drive is recognised in there
Nov 19, 2008 | IBM NetVista PC Desktop
Medion md40298 Notebook Logo
201 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
