Question about Indesit W 123 Front Load Washer
Getting to water pump
Indesit 125 wd
  • Indesit Master
  • 3,463 Answers
To gain access to the pump, remove lower plastic cover at front by prising down with a screwdriver, and remove same.
You will see the pump pre-chamber cover, unscrew it anticlockwise,and check for anything in there .
Refit cover and refit plastic panel.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
How to take out water pump
There are two ways of fixing drain pump depending on serial number of appliance. One easy mounting with three screws and the other is using the anchor tab where you should turn the drain pump counter clockwise and remove.
25602824-2cx31aa5jn1eijqkorrs11s2-4-2.jpg Also, follow this link:
http://www.espares.co.uk/advice/0/2308/indesit-washing-machine-pump-replacement-and-f11-error-
Dado
Mar 23, 2015 | Indesit Washing Machines
I have idf 125 indesit dishwasher i fitted a new water solioned but it will bring in water but pumps it back out and lights flash what is the problem
These machines use the wash motor to measure the water level.they measure the load on the motor which tells it when the water has reached the correct level.
Your dishwasher is sensing that there is too much water, they are a semi timed fill. try turning the inlet tap down a little and see if that helps.
If not the issue is either in your electronics or in the motor, The electronics sometimes get dry joints and if you have a soldering iron they are an easy fix.
Mar 06, 2012 | Indesit DF125 24 in. Built-in Dishwasher
Machine doesn't discharge fully
check that the out let pump filter is clear first,, then check that the drain pump is working,, it may be blocked up or stuck so it cant turn or maybe the drive motor has burnd out or the drain away pipe could be a little blocked up
Jul 01, 2010 | Indesit WA 125 Front Load Washer
Indesit washing machine model wn 665 ss not sucking water
this sounds like you have a blocked pump or broken pump this video might help
You-Tube video "19uprIcreD8" placeholder (do not delete)
You will find this link helpful
We have a Free full video library on appliance repair video’s
Jan 13, 2010 | Indesit WA 125 Front Load Washer
Indesit wd 125 had tripped a fuse switch
So many reasons. Check electronic board, loose cables, power inlet inside the chassie (noise cond).
Jul 27, 2009 | Indesit W 123 Front Load Washer
INDESIT WE 125
If the water continues to run into the washer after switching it off, then the water inlet valve is sticking, and needs to be replaced, this is the valve where the hose(s) connect to.
If it stops running in when you turn the washer off, then it is the water level switch that is not working.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Indesit WA 125 Front Load Washer
Indesit w12s
the code 10 on the model listed is a fault code for pressure switch,first check if appliance is draing water,if not listen for pump and check filter.
Jan 27, 2008 | Indesit WA 125 Front Load Washer
Indesit W 123 Front Load Washer Logo
319 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
