Pioneer pdp-436xde when I turn on the tv the seperate media reciever flashes from blue (on ) to Red ( standby) about 9 or 10 times ( the tv stays on blue and comes on. After the the 9th or tenth flashing of the lights on the media reciever it shuts down to red ( standby ) and the tv also shuts down to red standby. it is not an external cable issue as I have tested with new set of cables. regards Roger
  • roger_rennol Jan 31, 2009
    did as sugested no difference
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Almost always, a blue screen on a TV display indicates a video mute, there is no intelligent video signal detected. Additionally, this would refer to the Media Box in your Pioneer. Initial suggestion would be to disconnect/unplug all connectors to & from the display unit and the Media box, leave then unplug for an extended period. Should your concern be a system glitch, then the unplug would simulate a reset to revert the units back to factory defaults. Pls give this a try.
A friendly reminder, most Plasma TVs (to my knowledge) do not react favorably to constant powering off then on then off again. Additionally, when trying from the unplug condition, try the other connectors/jacks than the ones usually used.
Post back results/updates. Good luck and thank you for using FixYa.
Posted on Jan 31, 2009
  • Louie  Role
    Louie Role Jan 31, 2009
    Pls include the power plug to the mains/wall outlet. Leave the unit unplug from the mains for an extended period of time.
  • 19,396 Answers
The issue is either the external receiver or the input board on the TV.
Test the TV on a different receiver, if it works fine , get a replacement media receiver.
  • 679 Answers
There is some internal wire loose,
check all wire connected convergence circuit,
and let me know.
  • 11,896 Answers
Did you try using different input/outputs? It's worth trying, mabey one of your board capacitors are loose.
    President:
  • 1,952 Answers
You are having a problem with the convergence circuit. Since it recovers, I would first resolder the connections on the convergence ICs. These are large black ICs attached to a heatsink and will be marked STKxxx. Try resoldering and report the results here.
  • 6 more comments
  • mohammed marika thambi
    mohammed marika thambi Jan 31, 2009
    What's the typical monthly tab for a cable card?
    I have my cable box set to widescreen viewing (16:9)
    -Next to that setting I have the 4:3 material being stretched
    -I have 480i 780 1080i selected
    Do these settings still allow me to manipulate the way the screen looks
    by way of the pioneer remote. Basically, letting the TV rather than the
    cable box do the screen changes? I dunno I'm getting some 4:3 content
    with both black and grey bars but can't zoom the channel. Just wanted
    to see if I have things connected right
    D-Nice...anyone?
    Those setting are for an Oppo 971H dvd player *ONLY*. Here are some corrected settings for your 8300:
    Main Menu
    AV Selection: User
    Contrast: 32
    Brightness: +1
    Color: -13
    Tint: 0
    Sharpness: -3
    Pro Adjust
    Pure Cinema: Off or ADV
    Color Detail
    Color Temp: Low
    CTI: Off
    NR
    DNR: Off
    MPEG NR: Low
    These settings have no effect on picture formatting. Make sure you have
    auto size in the menu turned off or you will always get bars on the
    sides when watching 480i pictures.
    About 24 hours. Keep an eye on it. Sometimes it will stop and go to a
    light gray test pattern.....well it did when I had my 930.....just a
    heads-up.
    Did you sit around for 24 hours and just keep switching it back to the
    wash screen? Its changing to the grey screen every 20 minutes
    Mirrors out of location. But it usually throws the picture off
    center, also. This can be caused if the set is dropped or kicked badly.
    TWO: Out of focus. Can be caused by drift of the circuits or from a
    malfunction of the video drivers. You can check this by going to the
    crosshairs and see if the lines are sharp and narrow. If not, then the
    focus is off badly - most likely the blue gun. You may be able to set
    the focus and other levels for brightness and contrast and color to
    optimize this weakness as these are all somewhat interrelated,
    especially in the extreme settings. You can make adjustments for these
    above what is available from the OSD by getting into the service mode.
    See this web site for instructions on how to enter it. http://www.fixyourowntv.com/servicemenu....
    THREE: Worst case is the blue gun or projection tube is failing and
    needs replaced - which I don't recommend due to the very high cost of
    doing so.
    FOUR: And it is possible the blue gun/tube has been knocked out of alignment by dropping or moving the set.
    I favor the focus adjustment as the first remedy to try. You can do
    that yourself. But if it turns out the mirror is out of location or
    the blue gun is defective you will need a technician for help on those
    items.
    you are pretty sure that it is , in fact, IR and not burn in. I stayed
    up for about 14 hours doing the screen wash thing, then i got tired and
    had to shut off the tv and take a nap. Now I am back up and going to
    start it back up again. Should I already be seeing a difference? Can I
    just watch tons of Varied Dvds/HD TV etc to accomplish the same thing?
    I appreciate your help, It's just difficult to not use the tv for 24
    hours when I just got it.
    Check it and see if the IR is gone (it really should be).
    Watch only full screen programs with a contrast setting of 25. Also turn the power save mode to save2.
    You will need a SCART to SVHS
    adaptor (and cables) to feed both an SVHS cable and the red & white
    RCA audio cables into the Hauppauge card. Pay a bit more and get good
    quality cables, avoid the typical ‘wet pieces of string’ often bundled
    with most components. Don’t pay hundreds, but a few tens are worth the
    investment. But that can wait, anything will do for now. The
    improvement is only subtle to most eyes and ears, but it’s there, and
    if the quality is lost at this source stage, you can’t get it back.
    (Can’t polish a turd)
    You will probably want to use the other SCART plug
    on the Foxtel box and go directly into your TV set. Depending on your
    TV and Audio Setup, you may also want to run the digital audio out from
    the Foxtel box (or the analogue outs) into your TV or stereo. This will
    enable you to watch Foxtel without going via the MCE box in times of
    trouble, or when you want to use the ‘Red Button’ interactive features
    (more on the red button issue later). I haven’t used the direct
    connection to my TV for ages, but it’s a good option to have, and only
    needs another cable.
    The Foxtel box has a setup menu which allows you
    to access the preferred output video type. (Setup-System Setup-System
    Settings-Picture Settings-Video Output). It’s important to note that
    this option will affect BOTH SCART plugs. So if your MCE box is getting
    a SVHS signal from Scart 1, your TV will have to also have an SVHS
    input via Scart 2. There is also a composite video output on the Foxtel
    box, so you’ve got a choice of what to use, depending on your setup.
    Just remember that signal quality improves in this order… RF (aerial
    plug type), Composite (PAL in Foxtel talk), SVHS, RGB / Component. I
    haven’t seen any MCE tuners that accept an RGB or Component input, so
    SVHS is your best option.
    then loose connact the power supply in ur home plug pin check the other plug
    Genius:
  • 1,913 Answers
Ok first reatch all connection .check yourpowersupply waltage and earthing working properly.
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Hi I have a Pioneer PDP-436XDE its over 3 years old and has worked perfectly until today when it switched itself off and would not switch back on. Ive unplugged it from the mains and left it for some time...
The reason for your tv not switching on properly may be due to
The main filter capacitor or other filter capacitors in the low voltage power supply is dried up and this can cause all kinds of regulation problems.
The power supply regulator is defective (or marginal) allowing excessive voltage on its output and then the X-ray protection circuitry shuts you down.
blue or red colour may be due to fault in chroma decoder circuitry.
Jul 05, 2008 | Pioneer Televison & Video
PDP - 436PG display turns off then straight off and the red standby flashes 3 times, pauses then repeats
That is an error code that likely means power supply issue and based on brand not likely to be a do it yourself fix. Consider having a authorized Pioneer service center look at it and get an estimate.
Nov 05, 2012 | Pioneer PDP-4360HD 43 in. Plasma...
Pioneer pdp-ro4e keeps going on standby
my plasma pioneer tv gose in to a pioneer media reciver my tv wont come on and they both flash green red green red please help
Mar 08, 2010 | Televison & Video
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer PDP 436XDE
hi there, you have to send if for repair, tech people knows the prob., there a defective part to replaced. do some test and check up at the horizontal and power supply section. ty
Feb 18, 2008 | Pioneer PureVision PDP-4300 43 in. Plasma...
Returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
Oct 31, 2007 | Pioneer PureVision PDP-5040HD 50 in....
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
