Question about IBM (40K1042) 36 GB SAS Hard Drive
My computer had a virus so i took the hard drive out put it in an external shell casing to access on another computer. Unfortunately it fell and now i cant access my files. Is there any way that i can get my data off this drive
    Problem Solver:
  • 15 Answers
You should recover your data through any specialist of hard drive recover data
Posted on Jan 31, 2009
Lacie Case Only lighting up when HD is disconnected
I had the same problem with a 1TB hard drive. The fault was caused by the casing being knocked from the computer and falling onto the desk. If the hard drive hadn't been powered up it would have been ok...
I removed the hard drive from the casing and fitted it into my computer as a slave drive, hoping to access all the music and movies stored in it. No go .. But, it's worth you fitting your hard drive as a slave and trying the same. It's worth a shot.
I took the hard drive to a computer market here in China, where I work. These guys take hard drives apart to fix them, if possible. They couldn't fix my hard drive as it had been powered on when it fell ..
However, I bought a new desktop hard drive and they were able to transfer 95% of all things from the old hard drive to the new one. The cost of transferring from the old hard drive to the new hard drive was the same as the price of the new hard drive. That specialist service doesn't come cheap ... but it can be done. I paid simply because I didn't want to lose what had taken more than a year to download.
Try fitting your hard drive as a slave to see if you can access the information on it. If not, a new hard drive and the cost of transferring your music from your old hard drive may be the only course of action left open to you
Jun 05, 2013 | LaCie Big Disk External USB 2.0 1TB Hard...
I have 1tb western digital external hard drive. It fell at the usb port got broken, so I went ahead and took it out of it's orginial casing. Placed it in a docking station and all i get is a blinking...
these have software in them for the board in the factory case ...you will have to use a data recovery software to recover contents then reformat the drive OR try installing it as a second drive inside the pc directly to the sata/ide cables not usb. good luck
May 08, 2011 | Western Digital My Book Essential 1TB...
I have an external hard drive 120GB , unfortunately it fell down, my PC can no longer recognize it, is there any possibility to retrieve all the files stored in it tnx
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
May 02, 2011 | Computers & Internet
I have an seagate freeagent 500gig external hardrive and it fell off the counter and the part that connects to the cable for transfer data snapped off from the drive. I wiped my laptop and now I can't get...
there is,open the 500gb external case and take out the hard drive. go to your nearest computer shop and pick up an empty external hard drive case for internal drives.make sure its a sata drive,get your hard drive and put it in and reconnect it to your computer. those cases run around 80 bucks to you may need to look online for one to get a better deal
Mar 07, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How does a external hard drive work, and does it make my computer run better, I have purchased one but I am confused on how it works.
An external Hard drive is used to store information in any format. Ususally it is connected to USB, but it may happen that it is connected to either e-sata, which is the fastest or firewire.
when connector is inserted into the socket (USB, e-sata, firewire) Windows will automatically detect it. You can find your external Hard drive in My Computer, normally labeled removable drive. You can then double click it to access the information on the drive, or copy information to the drive. This means you can easily make a back up of all your files. Now if you so wish you can store it for backup purposes or you can use it to transfer information, contained on it, to another Computer/Laptop. An external Hard drive does not make your computer faster, but it does in a sense make your computer perform better,as it takes away the need for that data to be stored of your main boot hard drive. Therefore making virus scans on your PC run quicker and your PC has more space on it's main boot hard drive to perform tasks if it needs to.
Please rate my expertise, it's the thumbs up on the top right hand side of this solution.
Thanks
Nov 04, 2010 | Computers & Internet
Unable to access files
To access the files off the hard drive another way - remove the hard drive from the case and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. If the computer see the hard drive as an external hard drive/storage device and you can open the folders and files then backup your data. This also indicated the hard drive is OK and the Western Digital case/electronics is faulty.
To use this as an external USB hard drive, put the hard drive in an USB adapter case.
Sep 09, 2010 | Western Digital 320GB MyBook External USB...
External hardrive problem
try do access it with a version of linux. linux is a free operating system.
Aug 04, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Fell and now cannot access the drive
there can be 2 problems:
1) VIRUS INFECTED
2) DLL file is infected
May 17, 2008 | Fantom Drives 120 GB Hard Drive
Cannot access the drive
did you use anti spyware also?! or try another anti virus!
Mar 29, 2007 | Argosy 1 Bay HD-360U (DSARGHD360U2) USB...
IBM (40K1042) 36 GB SAS Hard Drive Logo
69 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
