Question about Samsung RS2578BB Side by Side Refrigerator
Ice maker refuses to work
I'm haveing a hard time figuring out why my ice maker only works when it feels like it! It seems to happen when the power goes out and we reset it then we never know when or if it will work? What do I need to do when the power goes out to get the ice maker to work again?
  • Anonymous Dec 23, 2007
    ice maker quit working
Try unplugging your unit that is what i tried and it started working normal again. i left it unpluged overnight though on the water pump
Posted on Jul 31, 2007
SOURCE:
Emerson ice maker not freezing ice, making small cubes and they are soft and mushy.. seems to not freeze ice solid and takes forever to drop ice
When was the last time you cleaned it by running ice machine cleaner through it. After a period of time algea, or slime will form on the chill plate where the ice is made. Sometimes its invisible to the eye, but it doesn't mean its not there. When this happens the machine will freezse the water, and when the ice tries to slide forward to the cutting grid, it catches on the chill plate. There are no sensors in the machine to tell it that this is happening and so the machine moves forward and starts running more water across the plate, which in turn runs across the ice caught on the chill plate melting it and using it as a ramp to fall into the bin melting the ice there as well. So, try cleaning it before taking any further steps, then if the problem persist feel free to get in touch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 15, 2012 | Emerson Im90 Portable Ice Maker
Automatic ice maker stopped working, Checked water supply to back of freezer, and the water supply is on. Arm on ice maker seems to be in correct position. there is no water in ice maker. can feel the...
Assuming you have active water supply to unit, either water valve or ice maker is bad. If Ice Maker is sending power to valve during Ice cycle, then valve is bad. If no power to valve during Ice cycle, then ice maker is bad.
Sep 11, 2017 | Amana ARB2557CSR / ARB2557CSL Bottom...
OUR ADMIRAL ICE MAKER HASNT DROPPED ICE IN ABOUT 2-4 HRS. WE ALWAYS ADJUST THE ARM MANUALLY WHEN NEEDED AS THERE SOMETIMES IS SOME ICE CUBE BUILD UP. THAT DOSENT SEEM TO BE THE PROBLEM NOW. THE TRAY IS...
They sometimes get frosted up and don't want to work the motor properly...if you can get the face of it off, take a hair dryer and heat it up until the frost melts off...don't spin the fan motor if you have one on that unit. Then put it bad on and see if that will help if it doesn't you may have to replace the whole unit. They run around $190 if you do it yourself...not too hard of a job.
Oct 29, 2009 | Admiral AAV7000A
Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The ice maker stopped working, gradually over a 3 day period.
It sounds like your harvesting motor failed. If you feel comfortable working on it, you can pull the ice maker out and remove the harvest motor and have it replaced. If you don't feel comfortable pulling out the harvest motor, pull the ice maker and replace the whole unit. They are a little tricky getting them out but if you take your time and don't rush, it is a doable fix for the typical do it yourselfer
Jan 11, 2018 | KitchenAid KSRB25FRBX Aluminium Side by...
Whirlpool side by side s20erww2v american f/freezer
Is the ice bucket still full? Ice makers have built in mechanism to cut itself off when ice bucket is full.
Sep 12, 2017 | Whirlpool Freezers
KitchenAid Superba Architect KSCS25INSS - Ice Maker not working
I have the exact same problem. If you figure out what happened, and why we are not getting any ice, please let me know. I can be reached by e-mail at [email protected]. I would greatly appreciate any assistance you can offer to get the ice maker working again.
Thank You in Advance,
Tom
Sep 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not working
It is under warranty, please call for service before it runs out!
Jan 03, 2008 | Refrigerators
Icemaker not getting water
water despenser is working fine,but ice maker is not working
2 yr old maytag french door refridgerator
Dec 27, 2006 | KitchenAid KSCS25FKSS Side by Side...
Samsung RS2578BB Side by Side Refrigerator Logo
102 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
