Question about Intel Frontier Design Wavecenter/PCI Audio Card Sound Card
DRIVERS PROBLEM WITH MY FRONTIER FRNU302 LAPTOP
I HAVE A FRONTIER LAPTOP FRNU302, INEED THESE DRIVERS FOR IT SOUND, VGA, MEMORY SLOT & WLAN. PLEASE I NEED THEM QUICK, ALSO I WILL BE GLAD IF ONLY YOU CAN DO THE FAVOUR, THANK YOU WILL BE EXPECTING TO RECIEVE YOUR MAILING. THANK YOU
3 Suggested Answers
SOURCE: need VGA driver for NEC VersaPro VA11j laptop
go for intel download center
Posted on May 23, 2009
SOURCE: intel p4 fw 82801db mother board vga & sound
download driver vga y sound fw82801db
Posted on Jul 13, 2009
Toshiba Satellite L655D s5050 when turn on power comes up charging light comes up disc drive works but nothing on screen and the vga port didnt work as well
Nothing on internal monitor screen, and nothing on external VGA monitor?
You have a bad graphics chipset. This = replace motherboard.
Before you rush out to buy a motherboard, let's review on how to properly connect a VGA monitor to that Toshiba Satellite L655D-s5050;
1) Laptop OFF, monitor OFF, connect the VGA monitor to the RGB port on the side of the laptop.
2) By DEFAULT, the display should show on the external VGA monitor.
DOES NOT mean it will.
No display on external VGA monitor?
Press, and hold down on the Fn key, tap ONCE on the F5 key.
(O-N-C-E. NOT repeatedly!)
Still no?
Hold the Fn key down again, and tap once more on the F5 key.
Still no?
Hold the Power On button down until the laptop turns off.
Remove the VGA cable, and all external cables/devices.
Close the laptop, turn it over on the table in front of you.
(I recommend a soft, static free cloth on the table, to prevent scratching the table, and laptop)
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Memory Compartment Cover.
(Middle of laptop on bottom. Rectangular cover with three Philips head screws)
Make SURE your body is free from Static, and remove all ram memory modules. (Slot A, and Slot B, IF, there are two ram memory modules)
Handle the ram memory module by the BODY. The body is everywhere, but the gold plated contact pins on the bottom.
The body is coated with a see-through protective plastic.
Refrain from touching the gold plated contact pins.
Clean EACH gold plated contact pin with a pencil eraser.
BOTH sides.
If using a pencil eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band contact the gold plated contact pins.
Just rub up, and down on each pin.
When finished use air to remove the eraser dust. You can use a can of compressed air for computers if available, or air pressure from your mouth will be sufficient.
Reinstall just one ram memory module, (If you have two), in Slot A.
Make SURE it is in Slot A. The Processor reads Slot A first. If no ram memory module is in Slot A, the laptop will not work.
Put the Memory Compartment Cover back on.
Reinstall the Battery. Turn the laptop over, and open it back up.
Plug the AC adapter (Charger) in.
WAIT 1 minute, turn the laptop on. Still no?
Turn the laptop off, and attach the external VGA monitor again.
Try it. (Don't forget you may have to use the Display Toggle-Over key)
Still no?
I suggest the graphics chipset is bad. Motherboard replacement.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 23, 2012 | Toshiba Satellite L655d-s5050 2.1ghz 3gb...
On the ASUS B53E laptop, in the slot were the mini WLAN wifi card goes can you a longer WLAN card in the empty slot horizontal from it and is it hard to redirect the wifi antanes to that area without...
You need to make sure the card is compatible with your laptop, and that it fits. If you have a card that fits these conditions then fit it and install the drivers. But the card must go in the correct slot.
Apr 12, 2012 | ASUS Computers & Internet
My toshiba satellite l305d laptop does not boot,screen is blank,fan spins,hdd led does not blink,wlan led does not display,dvd rom light blinks,power led is on
If the power LED lights up it indicates that the laptop is getting power from the AC adapter. Most likely there is nothing wrong with the adapter but just in case test it with a voltmeter to make sure the output voltage is correct.
Also try this. Unplug the AC adapter, remove the battery and wait for 1-2 minutes. After that plug the AC adapter ans try starting the laptop again. Sometimes this trick helps.
It also could be a memory related problem. Try reseating the memory module, just remove it from the slot on the motherboard and install it back. Try installing the memory module into the other slot (if it's available). If you have two memory modules installed, try removing them one by one and start the laptop just with one memory module installed.
If the laptop starts fine with one memory module in both slots, but will not start with the second memory module in both slots, the second memory module is faulty. Replace the module.
If the laptop starts fine with both memory modules when they are installed in the slot A, but will not start with both memory modules installed in the slot B, the slot B is faulty and you'll have to replace the motherboard or use only one memory slot.
hopeyour problem solved
if you find this is helpful for you so please rate me this will encourage me todo more free work..
regards'
sandy
Sep 05, 2011 | Computers & Internet
I want land driver and vga driver fo my msi vr300x. model no. ms-1436.
Here go to this site. You can download your VGA Driver. but it doesnt have driver for lan only WLAN
here if the link. CLICK ME
Hope it somehow helped.
Jul 05, 2011 | Computers & Internet
Need windows 7 drivers for wlan, sound, lan, video
Hi, copy this link, I think this is for your laptop.
http://driverscollection.com/?H=AV6200H60-01&By=Averatec
If you need more help, please ask.
Regards - Anthony
Feb 01, 2010 | Averatec 6200H Notebook
MY SOUND DRIVER NOT WORKING . I LIVE IN PAKISTAN .
Please try to check if you sound card driver is properly installed in your saystem and also try to check if your driver on audio card can support the currentl platform Operating system you are using now. Then if worst comes then reinstall your audio driver using the driver of your laptop if you are using onboard audio card.
Thanks
Aug 04, 2009 | Maxdata M-Book 1000T Notebook
Wipro Laptop Driver
I HAVE WIPRO LAPTOP,MODEL :WIVNB7B1600,I FORGET BIOS PASSWORD........PL SOLVE MY PROBLEM
Jun 22, 2008 | Computers & Internet
Audio driver
You have to download it from this link click here
Read it to find the driver you needed... sound, vga, etc...
good luck...
Jan 29, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Ipaq 6515 & WLAN?
Buy a WLAN sdcard to get WiFi connectivity. You will still have the second minisd slot available for a memory card.
Sep 08, 2005 | HP iPAQ hw6515 Pocket PC
Intel Frontier Design Wavecenter/PCI Audio Card Sound Card Logo
415 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
