Question about HP Photosmart C5280 Printer
HP photosmart C 5283:message on blue display 83C00020
Or when initialization beginning - C4EB8000 error and then " turn printer off and on " message appiers ;(
    Genius:
  • 2,120 Answers
Your scanner unit has failed. Uneconomical to get repaired.
Posted on Jan 31, 2009
The error message is Oxc18a0001. What is wrong with it. I've turned the printer off like it said to do, with no change.
Error seen on printers HP: HP Photosmart 7280, C5180, C6280, HP photosmart 8250...
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says "System Configuration Menu". 2. Press and release the "OK" button.
5. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
6. Press and release the "OK" button.
7. Display should say "Hardware failure status: Clear. Press OK to clear".
8. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
9. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
May 06, 2011 | HP Photosmart D7460 Printer
I have a HP 6180 all in one printer power error code
Read through NINETEEN(!) other FIXYA "solutions" for the '83C00020' error: http://www.fixya.com/tags/83c00020
Pick the one that works for you.
Jul 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have an HP Photosmart 3210 All in one printer and when I turn it on the 83c00020 shows up on display screen and will not allow me to print. It's also the camera icon is flashing on the side.
as posted for another model, I solved the described problem by holding down the "OK" button at the same time as the "ON-OFF" button on the printer console.
Jan 25, 2010 | HP Photosmart 3210 All-In-One InkJet...
My HP C4180 when powered up shows on the display screen the following: 83c00020 and does nothing else. The only way that I can power it off is to unplug the printer from the wall outlet.
press cancell (red x)button adn power button at same time then release.you will see enter special key combo on screen. then press blue button once then green button once then gray button once. it willshow some support url... then press blue button 2 times you will see reset menu.press ok on it. then press blue button 2 times agaiun you will see semifull reset. press ok.then pritner will turn off.turnm it back on it will get resolved.
Dec 16, 2009 | HP Photosmart C4180 All-In-One InkJet...
HP Photosmart 6180: error code:83C00020?
I cannot get the unit to work at all, it will not turn on or off. On the display screen I get the error message 83C00020 and the memory card light continues to blink on and off. I will not print, scan,fax or copy. I cannot override, I have tried the # and 6 reset but to no avail. I have called tech support and they said it was a 'hardware' problem that could not be fixed at home. Of course, they wanted to sell me a new printer!?! Any suggestions? I am stumped and frustrated.
Nov 18, 2009 | HP Office Equipment & Supplies
Error code 83c00020 on screen when power on. help?
The information you have left is a bit limiting however best guess you have a driver problem, worth a try- replacing the driver
The latest version can be downloaded from the HP website
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=443024&lc=en&cc=us&dlc=en&lang=en&cc=us
If you are unsure how to swap out a driver leave a comment and I will run you therough it
Sep 15, 2009 | HP - HP Photosmart 8250 printer
I get error C4EB8000, turn off and on printer
I have the same problem. It's a problem in logic board ***'y.
Aug 10, 2009 | HP Photosmart C5280 Printer
Hp c6180 all-in-one error message 83c00020
Try unplugging the printer from power for about 10 minutes and then reconnect it and see if that will reset it. You mentioned the error code 83c00020 is that on the printer screen or somewhere else?
I wasn't able to find that exact error is that the way the error actually displayed?
Reply back and let me know. Hope this helps. Please remember to rate this information.
Thanks
Nov 10, 2008 | HP Photosmart C6180 All-In-One InkJet...
Error on the display -
I had the exact same issue with one of these printers. 83C00020 on the display with a blue background. printer will not power off.
Try this - Press and hold the OK button then press the power button to reset the printer .
I did this and it powerd on ok and is now working fine.
Apr 18, 2008 | HP Photosmart 2575 All-In-One InkJet...
Hp photosmart
try this site
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=441240&dlc=en&lang=en
Dec 07, 2007 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart C5280 Printer Logo
1,381 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
