Question about Poly-Planar Poly Planar Ma4054rc (W) Ir Remote Spkrs F/ Mrd 60 4
The CD player doesn't work and says " E-03"
The cd Player SRD 60 doesn't work it says " E-03" in the manual they just say that we can put on reset, it restart the cd player but after it doesn't work
Reset CD Player
Unhook the battery - wait a few minutes - reconnect it. If that doesn't help post back.
Dec 20, 2011 | 2004 Pontiac Bonneville
Cd player dont work
Is it a CD player? Are you trying to play DVDs? Does the CD player show up in device manager? (Right click "My Computer", click Properties, Hardware Tab, Device Manager. If it doesn't show up at all then the drive probably needs to be replaced.
Nov 30, 2011 | Computers & Internet
ONKYO CR-315 cd player locked.
Hello
Just try to reset the CD receiver by holding the clock call button and pressing the STANDBY/ON button.
Nov 30, 2011 | Onkyo CS5VL Super Audio CD Player Black...
Jensen Personal CD Player Model CD-60 won't play cds. It starts and then shows "ER " message. I've put in fresh batteries - no change. Appreciate your help, thanks so much!
Have you try a Cleaning Disk. Maybe you can use a compress air can (usually sell in pc/electronics stores) and clening up the laser lens. Check for dirty on discs, water drops or scratches. Try another CD
Hope this help.
Regards,
Mar 13, 2011 | Jensen CD-60 Personal CD Player
CD Player does not work. Error 03 message is
Dirty CDs can skip or just stop playing For best results, use a CD cleaning fluid and anti-static cloths made for cleaning CDs. If these tips don't help you might have to buy another copy of your CD, but first try it in another player because some CD players are more sensitive than others to scratches.The last option is to replace the CD Head by taking to a nearest service provider.
Dec 28, 2009 | 2004 Mitsubishi Endeavor
03 vibe cd player will not respond
I blew a fuse controlling the radio, charging system, turn signals, heater fan, ,etc..this ran down my battery.
When I replaced the fuse, the CD player would not respond, but the radio worked.
I disconnected the battery for over 30 seconds, hooked it back up, and the time reset on the radio to 12:00 and the CD player works again.
Jan 23, 2009 | 2003 Pontiac Vibe
How to Remove Car Radio from Nissan Murano
If you disconnect one of the battery cables for about 30 sec and reconnect it, that will reset the CD player. Then you can put in the key and see if can eject the offending CD. My bet is that it won't. I own a 2006 with a failing CD (getting it replaced on warranty next week). The CD player in these cars is a real stinker. Nissan should be ashamed.
Dec 19, 2008 | 2003 Nissan Murano
Poly-Planar Poly Planar Ma4054rc (W) Ir Remote Spkrs F/ Mrd 60 4 Logo
Top Poly-Planar Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Poly-Planar Boating Expert? Answer questions, earn points and help others
