Question about Combi Centre DX - Mango
All my radiators dont heat up
Ive just had a large extention built and have a new central heating system fitted. i have a new baxi combi he duo tec which runs 16 radiators, i have 1 bath and 3 showers.
the water is always ok but when i turn my radiators on theres 2 that never heat up and one only gets warm. the plumber just makes excuses up saying just turn them all up high then start adjusting them until they all are on then leave them all on that setting and control it from the thermostat. iv tried this but it doesnt work. i feel as if he is messing me about.
i explained how many radiators and showers ect i wanted in the house and he recommended this boiler he said this one would be more that enough.
is it a case of the boiler not being powerful enogh or has it been fitted wrong
  • Roberta Smith
    Roberta Smith May 11, 2010
    have you bled the air out of the system yet ?
  • 350 Answers
I must go to bed now but you may want to try going to
to see if this helps!
Hopefully someone else at FixYa will help you while I'm sleeping!
Good Luck!
all my radiators dont heat up - 0dc2daf.jpg jackiaria
Posted on Jan 31, 2009
Baxi duo-tec boiler - when water comes on flame roars up. When i put the heating on the flames roar for 5 minutes then die down.
is the boiler a combi if so have you checked the pressure. it needs to be at 1.5 bar 2 bar at the most . also check that the heat the boiler is producing is completeing the circuit on the heating if you have access to the pipe work there should be 2 or 3 22mm copper pipes. now turn the heating on and check which one is getting warm. the one that is is your flow and in about 2 to 3 min there should be one more pipe getting hot let me no if this is the case
Oct 27, 2012 | Universal 900MM Super Thermocouple Baxi...
try bleeding the radiators in the order of downstairs first and then the upstairs and try to bleed them in the order they fill, trapped air can take a while to escape, a good sign on a radiator is the bottoms being warm where the tops( where the air is trapped) stays cooler, a sure sign to which radiator needs bleedin, hope this helps, colin
Apr 02, 2010 | Heating & Cooling
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
I can only get heating to the radiators upstairs, not downstairs
balance the rads.
upstair radiators turn all valves off,heat will then divert downstairs,open valves upstairs 4 turns on locksheilds and number 4 on trvs if u have any.
then if that does not work get a combi or powerflush.
if u cant afford then drain a little from rads,get x300 sludge remover from plumb shop and put in header tank(not hot water tank).
then fill system up and repeat balancing.
Dec 26, 2009 | Desa International CBN30T Central Heating...
Fitting room stat
take the link out and fit stat wires in its place,will work then.
Dec 18, 2009 | Desa International CBN30T Central Heating...
My daughter has a Baxi Combo 105e fitted with an optional timer. I believe that the timer is possibly a Grasslin although it has no name on it. Although the clock goes round, the Central Heating doesn't...
I have a Baxi Combi 105 HE boiler that has just been fitted and it has the optional 7 day digital timer but no instructions on how to set it does anyone know where I could get them from. Many thanks
Feb 21, 2009 | Hardware & Accessories
Re pressurise the BAXI DUO TEC COMBI 28 HE A
I represurised mine by the following:
1. unscrew the left hand circular tap all the way
2. slowly unscrew the right hand circular tap untill you hear the water coming through.
3. turn off both taps when pressure is good
Dec 28, 2008 | Kitchen Appliances - Others
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Our Baxi combi 130 HE heats the water OK but will not heat radiators. This has happened after a period of not using the radiators (ie. over the summer)
check the pressure it should be in  the green band, check the pump, inside the boiler cabinet lower right.
Oct 29, 2008 | Heating & Cooling
Combi Centre DX - Mango Logo
464 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
