Question about Sylvania SCR4966 Clock Radio
CD won't play
The CD is supposed to "spin up" and stop at one before being played, but I often have to switch it on and off several times before the number 1 pops up. We have two of these, and they're both doing it a lot. We've tried blowing them out with canned air. HELP!
  • Susan StLaurent Aug 12, 2007
    I've cleaned it with canned air. That doesn't help.
    Problem Solver:
  • 18 Answers
Clean The Laser Lens That Read The disc
Posted on Aug 09, 2007
SOURCE:
My cd part of aiwacd3 wont play any longer. i looked through the top window and it appears that the disk does not fit centrally under the playing head sometim and then the head spins a few revolutions,...
hi there.
Although CDs are still the preferred method of audio distribution, CD players are quickly being phased out in lieu of MP3 players. If your old CD player stops working, it might be a little panic-inducing, but fear not. If the CD player turns on but does not play CDs, then the problem is not with the power cord or the circuity (which are generally more expensive to repair rather than fix) but with the lens. There are several troubleshooting steps that you can take to fix a CD player when it won't play.
Step 1 Remove excess dust from the CD player. Dust is the number one enemy of electronics, and it can corrode even the most resilient device. Make sure to dust in between buttons, knobs, power cord(s) and audio-out ports. Note: use a dry duster, as moisture will harm your CD player further.
Step 2 Use a disk-based lens cleaner to remove ground in dust or dirt from the CD player's lens. These lens cleaners look like a regular CDs, but have specially-made bushes on the reverse side that gently remove excess dirt from the CD-reading lens. Simply put the CD in your player, and press the "Play" button to clean the lens. Do not run the cleaner more than once, as excess brushing can cause scratches on the lens.
Step 3 Polish the lens. Use a glass or eyeglass cleaning solution and a lint-free cloth to gently polish the reading lens. Clean it by using a low amount of pressure and softly polishing the lens and its surrounding area using soft, circular motions. Do this for about a minute or two and then allow the player to sit for a few minutes before trying to play a CD.
if you need more info go to this link.
cd won play Google Search
Dec 11, 2017 | Audio Players & Recorders
Why does my CD player say no disc?
IS IT A RECORED ONE, OR STORE BOUGHT, SOME HOME MADE ONES WILL NOT WORK.
Jul 07, 2014 | Audio Players & Recorders
Bose wave radio cd won't play cd's
If your CD is not scratched,the optical lens need replacement.
Apr 02, 2013 | Bose Awrc1g Wave Radio Cd Player Only -...
Cd player won't work on my CFD-560
Hello
Insert a lens cleaning disc into the system, and play it at least three times, by eject it out and reinsert in each time. If it does not help you, the laser pickup unit of your Cd player should be replaced with same type and number. OK.
Feb 03, 2012 | Audio Players & Recorders
My Wurlitzer 1015 100 cd jukebox wont play cd's
The problem may be in the power supply, it could be dry (cold joints in the USA) joints that are giving you problems. If you have the manual try checking the voltages at the power supply before and after you get the problem. It could be that once the jukebox is aired that the problem starts.
Regards
Alan Hood
ami-man
UK
Jan 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
CD player acknowledge CD, starts to play, then stops
I belevie you have problem in laser assembly it might not worth to repair it
Cheers
Dec 10, 2008 | Audio Players & Recorders
LAPTOP DVD DRIVE WONT PLAY DVDS
ok " get a CD/ DVD cleaning disk , you pop that in and it will clean the lens inside, and they don't cost much, but do so much
good. happy movie watching
Jan 22, 2008 | Acer Aspire 5610-4648 Notebook
Sylvania SCR4966 Clock Radio Logo
100 people viewed this question
Top Sylvania Audio Players & Recorders Experts
Ravi
ahmad
ahmad
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
