Question about Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000
Mixed up multimedia keys
My multimedia keys on my Navigator Duo cordless keyboard are all mixed up. When you press the email key for instance, master mute comes up.
Take out the batteries, replace them, and hold the 'connect' button for 15 secs. Works a charm; the whole keyboard is reset.
Tim
Posted on Feb 24, 2009
How do I turn off the ringer off or lower the ringer setting on my Panasonic cordless phone model #KX-TG5432?
Note, in these instructions: {V} = down on Navigator key (large key in center of phone) {^} = up on Navigator key {>} = right on Navigator key
4 volume levels (high/medium/low/off) are available. The default setting is HIGH. 1 .Press {MENU}. 2. Scroll to "Ringer setting" by pressing {V} or {^}, then press {>}. 3. Scroll to "Ringer volume" by pressing {V} or {^}, then press {>}. 4 Press {V} or {^} repeatedly to select the desired volume. To turn the ringer off, press {V} repeatedly until "Off ?" is displayed. 5' Press {Save}. Note: When the ringer volume is set to off, the handset will display "Ringer off", and will not ring for outside calls. The handset will ring at the low level for intercom calls.
Apr 06, 2011 | Panasonic KX-TG5432 Digital Dual Cordless...
I have cordless key board i put a new battaries still doesnt work do you think the key board doesnt work
To fix the problem,
please press the connect connect button on the bottom of the mouse and the connect button on the reciever and relaese both the buttons together. this would rest the wireless connection and then the mouse should work fine.
regards.
Jan 29, 2010 | HP Multimedia Cordless Keyboard/Mouse...
I am running a model 1045 on VISTA. The sleep key puts my computer to sleep but what key wakes it up?
Normally when you put your computer to sleep with your keyboard you only have to press a key on the keyboard to wake the computer again.
I normally use my spacebar to wake my pc but any key should work fine.
Kind regards!!!
Jan 06, 2010 | HP Multimedia Cordless Keyboard/Mouse...
Logitech navigator duo wireless mouse/ keyboard mouse works but keyboard does not
Hi, I suggest you to contact the Logitech support for a replacement this is an hardware failure and it's covered by warranty terms.
If you are not under warranty you still can contact them as I know for instance in Europe they can offer you some
good deal on nowadays products for out of warranty people.
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Sep 27, 2009 | Logitech Keyboards&Mouses: Cordless...
Backspace and up arrow keys seam to stick
blow into the arrow keys and into the backspace key(maybe some dust is malfuncioning the keys
Jun 12, 2009 | Logitech Cordless MX Duo 967300-0403...
Getting full use of the keyboard
you may need to configure it. to do this, go to control panel, select "printers and other hardware, then click on "keyboards" and find your model.
Mar 28, 2009 | Logitech Wireless Access Duo Optical...
Random keys
Here is logitech  website. Download the software and driver and reinstall.
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en
Dec 22, 2008 | Logitech Cordless Desktop MX 967300-0120...
Hotkey problems
I had the same problem but finally found a solution hidden in the depths of Logitech. It's quoted below. I had to do it a couple of times before it worked, and it seems that you need to reconnect the mouse at the same time. I didn't the first time and then the keyboard refused to work. (Finger trouble?) :-(
Cheers,
Magani
The following is from :-
http://logitech-en-ap.custhelp.com/cgi-bin/logitech_en_ap.cfg/php/enduser/std_adp.php?p_faqid=28&p_created=1083786523&p_sid=hwmEUpij&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTkwLDE5MCZwX3Byb2RzPTg0NCZwX2NhdHM9JnBfcHY9MS44NDQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1teCBkdW8gaXRvdWNo&p_li=&p_topview=1
This article applies to the following products:
Cordless Access Duo
Cordless Acess Duo Optical
Cordless access keyboard
Cordless Elite Duo
Cordless MX Duo
Cordless Navigator Duo
You may be able to reset the keyboard and resolve the problem by clearing the keyboard capacitors. To do this, remove the batteries from the keyboard and type continuously on as many keys as possible for one to two minutes. This action should simulate touch-typing; you should not press and hold only some keys down.
After you clear the capacitors, replace the batteries and synchronize the keyboard using the following procedure:
  1. Make sure the batteries are in correctly. A diagram on the device itself or in the Getting Started Guide should tell you the correct polarity for the batteries.
  2. Press the connect button on the receiver.
  3. Press the connect button on the bottom or right hand edge of the keyboard.
    NOTE: If you are using a Cordless Desktop System, you must do this procedure for both the mouse and the keyboard.
The "Connect" button on the mouse is quite small and usually requires a pencil tip or other small object to push it. Remember, ALL Logitech cordless devices will have a synchronization button. If you have the "Cordless Mouse" with Model Number (M/N) M-RN67, the button will be located in a small hole on the lower portion of the back of the mouse. You will need a paper clip to access the button.
Jul 03, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Multimedia &internet buttons are not working.
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Jun 16, 2008 | HP Multimedia Cordless Keyboard/Mouse...
GE duo 21828 cordless telephone english user manual
Press down key until the handset menu appears and press "INT/OK" key
Press up or down arrow key to select the submenu "Resgister" and press "INT/OK" key
Handset display shows "SEARCHING".
Press and hold "page" key on the base station more than 4 seconds until acknowledgment signal is heard
Enter the PIN (default setting = 0000) and press "INT/OK" key
on the Handset
If the input PIN is correct the registration procedure will be completed with a confirm tone.
After a connection is established the name and number of the handset appear in the display
Note : The base will be ready for registration for 10 minutes when the page key is pressed and held for more than 4 seconds.
Please let me know how these phones have performed, are you happy with them. Thanks
Jun 09, 2008 | Uniden Cordless Phone
Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000 Logo
280 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
